Thread: If/then conditional formulas and schedules
    September 10, 2014
    28
    11:27 AM
    hey all,
    so i have not messed with conditional formulas much at all. i am trying to figure out how i would go about getting this to happen....
    attached is a schedule that i am working with. in the column D "total hot" for all the zeros, i want to find out if there is an easy way to be able to state "if this is zero then replace with ---"
    i am just not sure how i would write that.... if(HWSFU <OR = TO 0, REPLACE WITH "---"? i am sure that i am way way off. but anything would help. i just cant seem to find this information anywhere.
    thank you
Name:	2020-01-06 11_47_15-Window.png
    September 19, 2017
    Seattle, WA
    81
    10:27 AM
    You can't. A number field only displays a number and cannot be formatted as a text string. I really (really, really​) wish there were a way, but there isn't a way to do it currently. Dynamo could do those calculations and output the number as a string to a text-based shared parameter, but it will not update automatically.
    If it were me, I'd include the HWSFU even where not needed and just force them to zero. It ain't pretty, but at least the table would look completely populated.
    September 10, 2014
    28
    11:27 AM
    awesome, thank you for the response.
    February 22, 2013
    362
    01:27 PM
    Quote Originally Posted by Robert Roffe View Post
    We got this to work by using a Calculated Value (text parameter) with this formula:
    if(Pipe Size CW > 0' 1 1/2", "2''", if(Pipe Size CW > 0' 1 1/4", "1 1/2''", if(Pipe Size CW > 0' 1", "1 1/4''", if(Pipe Size CW > 0' 0 3/4", "1''", if(Pipe Size CW > 0' 0 1/2", "3/4''", if(Pipe Size CW > 0' 0 3/8", "1/2''", if(Pipe Size CW > 0' 0 1/4", "3/8''", if(Pipe Size CW = 0' 0 1/4", "1/4''", "-"))))))))
    Each Pipe Size is just a text string that's output by each nested if statement. That final "-" string is what the formula spits out if none of the previous if statements are true. The schedule is reading a Shared Parameter from the fixtures called "Pipe Size CW", but that schedule column is hidden so all you see is the Calculated Value. Obviously, we're doing the same thing for hot water, sanitary and vent.
    This was a huge pain in the butt to execute, all because "the standard" at our firm is to put that "-" in the schedule when the parameter doesn't apply. The managers who do the redlines at my firm refuse to recognize any graphical differences between Revit and AutoCAD, so we have to jump through these hoops to appease them.
Name:	Plumbing Fixture Schedule.JPG
    As for OP's question, you could do the same thing with fixture units. You'd have to have one of those if statements for each increment of fixture units, up to 10 or 15 (or whatever the maximum number of fixture units per fixture is that you want to allow for.)
  1. Conditional Statements in schedules
    Last Post: November 21st, 2017, 09:57 PM
  2. Visibility conditional statements formulas - HELP
    By allan120791 in forum Architecture and General Revit Questions
    Last Post: March 28th, 2017, 11:14 PM
  3. Conditional Schedule Formulas
    By cupraymyun in forum Tutorials, Tips & Tricks
    Last Post: December 7th, 2016, 07:41 PM
  4. Schedules - more than one conditional format?
    By DDenton in forum Architecture and General Revit Questions
    Last Post: November 28th, 2016, 09:00 PM
  5. Conditional Formatting Door Schedules
    By d.stairmand in forum Architecture and General Revit Questions
    Last Post: May 13th, 2015, 02:38 AM
