Thread: Problem with curtain wall
    Lurker
    December 30, 2019
    02:04 PM
    I'm really new in revit.I try to make curtain wall with this my family. When i use in project revit replace last panel with system panel. Then I tried to make a simple curtain panel. Var1 - I locked the outer lines to the main reference planes. I noticed that last panel from curtain wall been scaled and if revit couldn't scale revit replace with default panel. Var 2 - I tried to create reference planes and locked all lines to them. Then my last panel is out of set length. Thanks before!
Name:	simple wall 1.jpg
    3,125
    02:04 AM
    You need to provide more reference planes and constraints to define your expectations. If you edit your extrusion's sketch and turn on Automatic Sketch Dimensions you'll see how Revit is guessing, trying to constrain the shape you've drawn. Imagine a shop drawing telling someone how to define the depth, width and location of each corner and the width of the material you're using.
    A curtain wall panel has to be able to flex to fill the space between grids. Your family has to know how to maintain its form regardless of the overall width or height of the panel defined between the grids.
  1. Door curtain wall problem....help pls.....
    By mig3d in forum Architecture - Family Creation
    Last Post: February 17th, 2014, 12:58 AM
  2. Problem with adding custom curtain wall panels to curved curtain wall.
    Last Post: November 20th, 2013, 07:16 PM
  3. Curtain Wall Problem
    By Shields08 in forum Architecture and General Revit Questions
    Last Post: May 31st, 2013, 10:00 PM
  4. curtain wall profile problem
    Last Post: January 21st, 2013, 06:56 PM
  5. Curtain Wall Panel Problem
    By blimpman73 in forum Architecture - Family Creation
    Last Post: October 23rd, 2012, 12:13 PM
