Thread: Drainage
    October 7, 2011
    01:37 AM
    Drainage
    Is there any way of detailing underground drainage in Revit Structure 2011?
    If yes, are there any manhole/pipe families around?
    Regards
    stuhall
    Nantes, France
    1,381
    02:37 AM
    Do you need 3d? If yes, you will have to play a bit with 3d sweeps.
    Some workarounds can be setup, s.a. using adaptative components, or rebars shapes drawned by hand, hosted on a dedicated element. This way, connections are easy to define.
    The intended tool is Revit MEP.
    Hope it helps.
    March 21, 2011
    Brisbane
    293
    10:37 AM
    I created a Line based familiy which allow me to put an offset in either end from a known ref level.
    The offset is to the invert of the actual pipe.
    It might be other and better solutions but it does the trick.
    Cheers,
    johk
