Thread: Problem Windows Preview + AutoCAD (from Revit)
    Member Infinite's Avatar
    November 19, 2019
    Utrecht
    61
    07:31 AM
    Hello guys,
    There is a thing that is going on with the projects I'm working with. In Windows, on the side panel, it shows a nice and correct preview. But when I open it on AutoCAD, it shows a sheet being flipped/dissapeared.
    Is there any way to solve this?
    Note: The dwg file is exported fromout Revit 2019.2.
    3,194
    12:31 AM
    Looks like you've got three Viewports.
    Can you see whatever's in the top one in AutoCAD Model Space?
    November 19, 2019
    Utrecht
    61
    07:31 AM
    Yes, there are 3 viewports.
    The upper one has the good content, but its flipped while exporting to dwg.
    Thats the reason it isn't visible in the port itself.
    November 19, 2019
    Utrecht
    61
    07:31 AM
    Found the solution. Wel.. not really, but yes :P
    Updating to Revit 2020 solved the issue.
    3,194
    12:31 AM
    When you upgrade a project, an automatic AUDIT happens.
    I've never understood exactly what an Audit does, but apparently it can fix things you didn't even know about.
    I wonder if doing an Audit in 2019 would have fixed it?
    November 19, 2019
    Utrecht
    61
    07:31 AM
    I'm going to try that today.
    November 19, 2019
    Utrecht
    61
    07:31 AM
    Nope, same problem. I think there is an upgrade in some of the options in Revit or bugfix.
    Find the same description on this link:
    https://knowledge.autodesk.com/suppo...-DWG-file.html
    Thanks anyway Dave!
    Last Post: March 8th, 2017, 06:15 AM
  2. Revit 2015 and windows 10 problem
    By Marcel Jansen in forum Architecture and General Revit Questions
    Last Post: April 12th, 2016, 06:08 PM
  3. Who's running Windows 8 with Revit or AutoCAD?
    By tzframpton in forum Hardware and Infrastructure
    Last Post: September 4th, 2013, 12:09 AM
  4. Windows 8 (Consumer Preview)
    By iru69 in forum Out There
    Last Post: March 1st, 2012, 11:59 AM
