Results 1 to 10 of 14
Thread: MEP Objects showing up in all architectural floor plans
    September 23, 2015
    13
    03:57 PM
    We have 2 linked models with MEP services in them. The services are modelled at high level (eg up towards the ceilings if not above ceilings). We can see ducts, mech outlets, lights etc in all our floor plans.
    Architectural plans are set as all to associate level and follows:
    Top of view range 2300mm
    Cut at 1200mm
    Bottom of view range 0mm
    View depth 0mm
    No underlay on
    Any thoughts? I don't want to just turn off the MEP models - that kinda defeats the point!
    1,511
    04:57 PM
    Just turn off those categories in your view template.
    September 23, 2015
    13
    03:57 PM
    That doesn't really help us with coordination. We want to see the MEP that is at floor level.
    I tried importing the MEP model to an OTTB revit template. Same view range and underlays set as default...and it works the way I want it to - only services below the cut plane show up.
    1,511
    04:57 PM
    Ah OK, thought you didn't want to see it at all in your 'regular' floor plans.
    But in this case I can't really think about anything from the top of my head that will solve it, but have some things you could look at.
    Linked View and View range in the RVT Link Display Settings maybe?
    November 18, 2016
    149
    03:57 PM
    MEP families are generally rubbish from my experience, they have loads of 2D stuff that shows regardless of whether you want it to or not. MEP guys create their families solely for their own drawings (rightly so in some ways i guess) but they dont work well with other disciplines.
    2,732
    08:57 AM
    Ask them to change the visibility of the nested GA to not be visible at some detail level (I prefer Fine). If they accommodate then all you need to do is set the detail level of those categories accordingly.
    And next time put this in your BIM Execution Plan.
    November 18, 2016
    149
    03:57 PM
    That's the best way to get people to comply otherwise i fear you're fighting a losing battle.
    I know i was when i asked for MEP to make amendments to their families. My main bugbear was that they showed 2D symbols for the item that bore no relation to the size of the actual item and so when we came to do setting out of elements within ceiling panels we had no idea whether we could fit things in the panel we showed.
    10,790
    09:57 AM
    Quote Originally Posted by ceilidhhiggins View Post
    Cut at 1200mm
    View depth 0mm
    No underlay on
    So... It depends on WHY they are showing up: If they are showing Generic Annotations, as someone mentioned, its an easier fix: View Template : VG:RVT Link (Custom) : Annotations tab (Custom) : Annotations all off.
    Modeled duct above the Cut Plane shouldnt be showing up at all, unless something weird is going on in your View settings. Lights, EQ, Air Terminals.... May be issues with the specific families, which will suck. But usually the GA off deals with it.
    3,194
    09:57 AM
    2 Not allowed! Not allowed!
    Quote Originally Posted by robp View Post
    I hope they aren't reading this, but one of our consultant's families have a bunch of Sub-Categories:
    • #1 Red
    • #2 Yellow
    • #3 Green
    • etc.
    Rather than saying what those subcats are actually used for.
    Wonder where they got those names . . .
    November 18, 2016
    149
    03:57 PM
    • #1 Red
    • #2 Yellow
    • #3 Green
    • etc.
    i nearly posted that they have simply "ported" their CAD symbols through but didn't want to be overly critical, it's probably another case of the heirachy wanting Revit drawings to look like CAD drawings
  1. Replies: 16
    Last Post: June 12th, 2018, 09:43 PM
  2. Merging Mass objects and Cleaning up Floor plans.
    By RevitRyan in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 31st, 2015, 05:55 PM
  3. Lights showing on floor plans
    By MPwuzhere in forum Architecture - Family Creation
    Last Post: September 26th, 2014, 04:37 PM
  4. objects showing up on the wrong floor
    By tumbo in forum Architecture and General Revit Questions
    Last Post: July 2nd, 2013, 04:45 AM
  5. Objects appear in elevation on floor plans
    By galetondesigns in forum Architecture and General Revit Questions
    Last Post: June 30th, 2013, 09:53 AM
