Thread: Divided path - horizontal distance
    Lurker
    January 16, 2020
    02:53 PM
    Question Divided path - horizontal distance
    Hi there,
    I need make a sheet pile family en I want to use a spline which I want to make a divided path.
    The sheet pile has a flexible height with the bottom en top changing heights so I want to use 2 reference lines (bottom and top).
    When I make the reference line a divided path and set up the fixed distance, the distance measures between the points directly, like in a horizontal and vertical direction combined.
    This is not how I want the measurement. I need to set up only a horizontal distance which means the direct distance between the points won't be like in the set up.
    I added two sketches of what I mean: the points have to be like the second example, on the intersection between the purple and red lines.
    Does anyone recognize this issue and knows a solution?
Name:	2020-01-16 11_55_13-Autodesk Civil 3D 2019 - [Drawing1.dwg].png
ID:	38181Click image for larger version.
Name:	2020-01-16 11_55_30-Autodesk Civil 3D 2019 - [Drawing1.dwg].png
    3,228
    09:53 AM
    Welcome to the forum.
    Looks like Divided Path is not the tool for this task, because a divided path creates segments of equal length. In this case, I think each segment of curve between one vertical line and the next has a different length.
    Try this: draw those lines as reference planes. Host reference points on the spline. Then select each point and use "host point by intersection" then select a vertical reference plane. Now the point is under control. If the reference plane moves, the point will move. Once you have a skeleton of points under control, you can build the rest of the geometry.
    Last Post: July 11th, 2019, 06:13 AM
  2. Divided Path Points Displaying in Model
    Last Post: November 13th, 2017, 01:35 PM
  3. Distortion of adaptive component when placed onto divided path
    By YUMI_ in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 6th, 2017, 01:33 PM
    Last Post: March 2nd, 2015, 06:15 AM
    Last Post: December 17th, 2013, 10:45 PM
