Thread: Powermachine - Desktop
    October 29, 2012
    Graz, Austria
    20
    05:06 AM
    Cool Powermachine - Desktop
    Hello Revtianer,
    Our office want to buy a PowerComputer! we want to spent around 2000 - 4000Ç!
    It is manly used for a big projekt, opening and converting modells for clashdidection, we will use Revit 2020 and Navisworks 2020.
    The Desktop will be used also for client topics like visting the model with Enscape, twinmotion via VR (OculosRift,...)
    For the processor it should be a multi core, each core has to be ****, because (we know) Revit is puting his task only on one core
    RAM should minimum 64 GB
    Our officehardware is by DELL!
    Which workstation can you recoment us? Does anyone have same tasks in the ofice, some expierence? Which compostion of motherboard/processor RAM / VR-Glases can you recomment?
    I am glad about any advice
    KR
    Andreas
    11,039
    12:06 AM
    Quote Originally Posted by andreas2 View Post
    Hello Revtianer,
    KR
    Andreas
    Short Answer: Not a Dell.
    1,618
    07:06 AM
    I agree with Aaron there, and I would not go with HP or Lenovo or any of those brands either. Get yourself a custom build machine, but I understand that could be difficult if the company REALLY wants a Dell but in the end I'm sure you will be much happier.
    Only becasue of Enscape you need a gaming GPU, say a 2080 and as far as I know if you go to any of the big computer companies once you say 'workstation' you will get a Quadro.
    Even though shipping a machine from the USA is probably not worth it, check out REMISCS (he's very active on this forum when it comes to computer stats as well) to see what he does and build or get somebody to build something similar.
    I got myself a 8086 CPU (clocked to 5Ghz), with 32Gb, 512 Gb M.2 SSD and a 1070ti GPU for around 2700 euro (build it myself) so with a 2080 and more ram and probably a 9900k CPU right now you will stay under 4000 most likely and it will be much better suited for what you need.
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    132
    07:06 AM
    You can build a system like that for around 2000,
    https://pcpartpicker.com/list/VGtNvW
    Member remiscs's Avatar
    May 18, 2015
    Las Vegas, NV
    273
    10:06 PM
    I agree with custom built from a professional but if you ARE limited to dell, see what they offer with an intel i9 9900k or IF YOU MUST a Xeon E-2288G which is basically the Xeon counterpart to the 9900k. Scale down to match budget limitations but this is the best CPU for what you described.
    For client VR demos I would say go RTX 2080ti which has 11GB of VRAM, you do not want a bad demo experience to make you look bad in front of a client. If models are simple you can go down from there, no less than a RTX2070/2070 SUPER. The 2080ti is very close to the Quadro RTX6000 which cost $4000 USD vs the $1100 USD on the 2080ti to put it into perspective.
    RAM, no need to pay huge premiums for anything faster than 3200mhz if given the option. You should not use less than 2666mhz though. Going above 3200mhz RAM does show benchmark improvements but real world is much harder to notice and usually comes at a premium which could be spent elsewhere into the build where it would make a bigger impact on performance.
    Good Luck!
    October 29, 2012
    Graz, Austria
    20
    05:06 AM
    Thank you very Much! I will discuss it in detail with my IT-Department. KR Andreas
  1. Autodesk Desktop App
    Last Post: December 28th, 2016, 03:02 AM
  2. Laptop or Desktop?
    By cellophane in forum Hardware and Infrastructure
    Last Post: March 2nd, 2015, 07:21 PM
  3. Remote desktop
    By mdradvies in forum Hardware and Infrastructure
    Last Post: November 7th, 2014, 10:54 PM
  4. Desktop Sharing
    By Alex Cunningham in forum Out There
    Last Post: October 19th, 2012, 06:29 PM
  5. Desktop Shortcuts to RS
    By snowyweston in forum Worksharing, Revit Server & C4R
    Last Post: May 16th, 2012, 08:37 PM
