Thread: Title block parameters not directly editable
    July 7, 2017
    Hernando, MS
    560
    02:02 PM
    Our title block has all the usual parameters that normally show up as blue when clicking the title block, meaning each parameter can be clicked on and edited directly. However in one project none of the parameters show blue. The entire title block shows red (our standard element selection color), meaning none of the parameters can be edited directly by clicking on them. But they CAN be edited through the Properties palette, either for the sheet or for the title block instance. Sheet number, name, drawn/checked by, etc.
    I think the project was purged at some point, but these should all be stock system parameters (not shared parameters), so I'm at a loss here of why these can't be edited directly anymore.
    3,192
    02:02 PM
    What does it look like if you Edit the Family?
    July 15, 2014
    Nahville, TN
    53
    04:02 PM
    3 Not allowed! Not allowed!
    Is the title block object pinned in the project?
    July 7, 2017
    Hernando, MS
    560
    02:02 PM
    It's the same as if I edit the title block family from a blank project where the TB fields work as expected. It has all the normal labels with parameters set as usual.
    July 7, 2017
    Hernando, MS
    560
    02:02 PM
    Quote Originally Posted by zsmith3 View Post
    That's it. Thanks. Never seen that before. And since it's a Workshared project, when clicking on the TB, the "make editable" icon appears first instead of the Pinned icon, and I didn't notice in the Ribbon that the Unpin button was active.
  1. Title block shared parameters
    By Karalon10 in forum Architecture and General Revit Questions
    Last Post: August 11th, 2017, 04:44 PM
  2. View Title - Add instance parameter editable in project
    By KJE_ in forum Structure - Family Creation
    Last Post: March 31st, 2016, 01:26 AM
  3. title block parameters - can't find to delete?
    By CBukowski in forum Architecture and General Revit Questions
    Last Post: November 27th, 2012, 03:43 PM
  4. Replace tilet block with title block
    By Charles Karl in forum Architecture and General Revit Questions
    Last Post: May 4th, 2012, 10:48 PM
  5. Revision block and title block
    By soboyle in forum Architecture and General Revit Questions
    Last Post: April 25th, 2011, 10:22 AM
