Thread: Building Section V/G or Object Styles Problem
    December 19, 2019
    Muskoka Ontario
    4
    03:57 AM
    Hi RF,
    I'd like to see if anyone else has had this issue before. I think it would be called Node but doing some research have not found any solutions. I can't seem to find what is making the "nodes" that intersect so big I would like to modify the line type and/or hide these with the linework tool.
    TIA, Storm
Name:	Buidling Section Problem.png
    2,718
    06:57 PM
    yeah that is annoying. I think they are the projection lines perpendicular to the view (even though they are cut!). You can sometimes be successful in using the linework tool and a bunch of <tab>ing to get them to display thinner, or or filter/ override in view by element.
    December 19, 2019
    Muskoka Ontario
    4
    03:57 AM
    I will give it a shot thank you elton williams
  1. Object Styles
    By ThatBIMGuy in forum Third party Add-Ins, API and R&D
    Last Post: April 9th, 2015, 08:13 PM
  2. Building Pad Section View Problem
    By raphuss in forum Architecture and General Revit Questions
    Last Post: July 29th, 2013, 02:18 PM
  3. Losing Object Styles
    By Tim West in forum Architecture - Family Creation
    Last Post: January 15th, 2013, 11:42 PM
  4. Different line styles for Bulding section vs Wall section
    By NW_Reviteer in forum Architecture and General Revit Questions
    Last Post: November 13th, 2012, 10:17 PM
  5. Object Styles, Line Weights, and Line Styles?
    Last Post: October 23rd, 2012, 05:14 PM
