Thread: Linked CAD visibility
    Member tidalwave1's Avatar
    Las Vegas
    143
    02:18 AM
    Is there a way to find out how a CAD file was linked into Revit after the fact?
    Like if a linked CAD file was brought in 'current view only' how do I find out to which view it was actually linked in? and/or change to all views???
    Does that make any sense? Or am I flying blind?
    Thanks,
    Travis
    2,825
    08:18 PM
    Quote Originally Posted by tidalwave1 View Post
    Thanks,
    Travis
    Use dynamo to search all views for the cad file, but if the view has been deleted then it might be lost but if you find it there are delete element nodes in dynamo.
    Use Revit Lookup addin to find the element id, then select by id and click "show in view" and revit will search though all views. again, it might be lost if the view has been deleted, but if it does get selected (check properties browser) you can just hit delete. https://boostyourbim.wordpress.com/2...or-revit-2020/
    If it's linked in (and not imported) you can remove it through the manage links dialogue and relink it back in - without 'current view only'.
    Las Vegas
    143
    02:18 AM
    Thanks! I didn't think about ElementID. Obviously... Will look into the Revit Lookup addin.
  1. Elevation Visibility with a Linked CAD dwg
    By sheyweb in forum Architecture and General Revit Questions
    Last Post: December 21st, 2017, 09:28 PM
  2. Linked Revit Model Visibility Bug?
    By Uncommonb in forum Architecture and General Revit Questions
    Last Post: May 9th, 2016, 08:55 PM
  3. Linked Structural Visibility
    Last Post: October 27th, 2014, 09:56 AM
  4. Linked Files Visibility
    By ThatBIMGuy in forum Architecture and General Revit Questions
    Last Post: April 30th, 2013, 10:14 PM
  5. Linked Models and visibility
    By drafterjohn in forum Architecture and General Revit Questions
    Last Post: December 22nd, 2010, 12:37 PM
