Results 1 to 10 of 12
Thread: Can't find level line in detail view
    July 7, 2017
    Hernando, MS
    565
    05:20 PM
    I have a detail that's a callout of a building section, but the floor level line is missing. The building section shows the level lines, and the 3D extents cross the area of the detail callout, verified both in the building section and in a 3D view. I tried uncropping the detail view, turning on hidden elements, checked that Levels are turned on in V/G, checked that it's on the right workset, everything that I can think of, yet the level line is still missing. What am I missing?
    3,194
    05:20 PM
    When I can't understand why something isn't displaying properly, my default is always to blame a DWG.
    May 18, 2011
    Calgary, AB
    431
    04:20 PM
    filters, view template (or lack of it overriding). Cut with line is on?
    Wellington, New Zealand
    705
    12:20 PM
    Do Grid lines show?
    Sure its not a drafting view? (had to ask!)
    2,715
    09:20 AM
    Did you check that the 3d extents of the level are actually crossing perpendicular (ie. are being cut) to your view plane?
    July 7, 2017
    Hernando, MS
    565
    05:20 PM
    There are no filters on the view, and the template has Far Clipping set to Clip without line. Grid lines show, all levels are on the Shared Levels workset, and all levels intersect the entire building in all directions.
    There should be 3 levels visible (Ground Floor, Second Floor, Roof) but I can only see Ground Floor and Roof in this particular section view. Doing Select All In View only selects the two. If I uncrop the view and repeat, still only the two. If I turn on the light bulb and do it again, still only the two.
    The second floor level in this one building section (and its callout detail) are absolutely nowhere to be found!
    December 11, 2010
    Astana
    189
    05:20 AM
    Scope Box; workset.
  8.    #8
    2,734
    04:20 PM
    Try Select All in Project. Then Maximize Extents if you get all 3.
  9.    #9
    3,194
    05:20 PM
    Not sure which of you is the chicken and which is the egg, but Tim (RevitCat) did a blog post about Levels very recently
    http://revitcat.blogspot.com/2020/01...n-section.html
  10.    #10
    2,715
    09:20 AM
    After another quick scan I see no mention of Revit version.
    If you're in 19/20, double-check the level extents in 3D (yeah I'm still bangin' on about extents).
    If that doesn't produce juice, try recreating the section view from scratch to see if it's maybe a view corruption thingy.
  1. View Filters - Change of Detail Level
    Last Post: December 11th, 2018, 03:49 AM
  2. Use detail level to hide 3D geometry in plan view?
    By Sim_nn in forum Architecture - Family Creation
    Last Post: October 24th, 2017, 01:13 PM
  3. View Template Negates Default View Detail Level
    By evan.dodds in forum Architecture and General Revit Questions
    Last Post: March 11th, 2016, 09:09 AM
  4. View's detail level deos not match view template setting
    Last Post: June 11th, 2014, 10:41 PM
  5. Confused about View Scale and Detail Level
    By terran in forum Architecture and General Revit Questions
    Last Post: March 3rd, 2012, 07:06 PM
