Results 1 to 10 of 15
Thread: Need help with in place mass with divided surface
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    150
    04:14 PM
    Unhappy Need help with in place mass with divided surface
    currently im working on a project where i need 3D roof tiles, i normally use a sloped glazing family, but because this roof plane isnt perfectly square that doesnt work.
    Now im trying to do that with a in place mass with divided surface, i did this before, but i just cant get the panels to line up, they are always at an angle and impossible to get them vertical. in my other model it used them on, i did not need to do anything to the angle.
    I have to use this model to make 3D impressions, all my models before had 3D tiles and i want this one to have them to. without them it would look terrible. i am using a normal roof for now, hope the client still likes it.
    here is a google drive link with the project.
    https://drive.google.com/open?id=17o...49iMyK7ao-macc
ID:	38197Click image for larger version.
    January 22, 2020
    Lahore
    5
    07:14 PM
    These 3d roof tiles can be created via generic model adaptive family component and can also be placed as a beam system where you can create this roof tile in the structural frame family. Let me see if I can place these roof tiles on this type of roof and then I will inform you.
    January 22, 2020
    Lahore
    5
    07:14 PM
    I have created a single roof tile in the curtain family pattern based template file and then I have uploaded and placed them on the roof using the massing and dividing surface into rectangular patterns.. See the attachments.
ID:	38207Click image for larger version.
    January 15, 2020
    The Netherlands
    150
    04:14 PM
    Quote Originally Posted by Lets Revit View Post
    wierd that it did not work for me, i used the same type of family, the first time i used them they worked as intended, but this time they dont..
    can you send me that family to try?
    January 22, 2020
    Lahore
    5
    07:14 PM
    From the picture which you have attached it seems that you have not arranged the U grid and V grid. I have kept the dimensions of the grid the same as the dimensions of the curtain panel pattern. I do not have the laptop with me right now. I will attach the family file once I have it.
    January 22, 2020
    Lahore
    5
    07:14 PM
    Quote Originally Posted by Modderhoop View Post
    Where should I send you the family file? your email address?
    January 15, 2020
    The Netherlands
    150
    04:14 PM
    Yes sure, send it to jarnomodderkolk@gmail.com
    11,153
    09:14 AM
    Im sorry, but i have to ask: Why on earth is that roof not planar/flat?
    January 15, 2020
    The Netherlands
    150
    04:14 PM
    This is a common roof type in the Netherlands on older farmhouses and others, some modern houses like to bring that back a little. We call it a wolfsdak. for my client i have done a lot of other different versions of this house, with different roofs and window layouts, and this is just one of them, some other have just square roof planes, where i use my sloped glazing type no problem..
    11,153
    09:14 AM
    Okay, but where exactly is it not planar? In section, is it curved? If so, id probably do it with a Roof by extrusion, with vertical openings for the hips. Could still use sloped glazing then.
  1. Surface Pattern for Divided Surface
    By Mtel in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2015, 03:12 AM
  2. Is any better way to adjust divided surface?
    By leeway180 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: March 5th, 2015, 03:45 AM
  3. Mass without Sub-divided Surface
    By ZoLaDo in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 27th, 2013, 10:09 PM
  4. Can't get mullions on a divided surface?
    By genismk11 in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: January 19th, 2013, 12:11 AM
  5. Divided Surface
    By feio in forum Architecture and General Revit Questions
    Last Post: August 22nd, 2011, 10:36 AM
