Results 1 to 10 of 11
Thread: How can I get area totals for my various building elevation elements?
    December 11, 2019
    5
    11:55 PM
    I am fairly new to revit, using revit 2019 on a project.
    I am looking at a large 10 story building that the client needs square footage totals for various materials including brick/windows/granite.
    The elements are colored to represent the final color, there's two tones of brick that they need the separate totals for. Some of the elements are colored grey to represent the granite, need the total for that too. They also want the total glass; some of the windows are actual window elements, some are curtain walls.
    I'm currently drawing a hundred different fill areas to grab all these elements and add up the area totals. But is there a more efficient way to do this?
    I need these area totals for the whole building but also per view (per elevation) if that's possible.
    Thanks for any help on this
    1,519
    05:55 AM
    assuming everything is modeled correctly you can create a few schedules to get the totals. You will need a way to filter the different colors of brick, so have something in the type comments for example to filter on would work, just mentioning the color in there should do it.
    December 11, 2019
    5
    11:55 PM
    Thanks for the help, can I separate this information by view? We need it per-elevation. Thanks!
    1,519
    05:55 AM
    mmm, in general schedules are for the entire project, but if you really need to you could split them up by adding a parameter to every wall listing the elevation they are on. For example use the Comment parameter in a wall and just type North Facade and South Facade in the wall and filter your schedule on that. This however requires you to really take care of filling in the correct data or the wall will not end up in the right schedule or in any schedule at all. A lot of that could be automated with Dynamo I think.
    Maybe somebody in here has a very clever idea to make it a bit less user error prone
    December 11, 2019
    5
    11:55 PM
    that makes sense, but yeah, we certainly arent going to go chase down every wall type. window type. etc. to add that parameter. Hopefully something comes up to get this data within just a view, or organize it by view/elevation.
    1,519
    05:55 AM
    Like I said, Dynamo could help. One thing that comes to mind is place a large in place model around every facade and have dynamo get every wall that is inside that model and fill in the parameter.
    And I have done project that way. Not to split up wall types but to split a project by building. Every object in each building needed to get a parameter sa building code so we could filter on that and even export each building as a separate IFC model.
    And to be honest even filling in the parameter by hand is most likely faster then calculating everything by hand or placing filled regions especially if thing change.
    Member tidalwave1's Avatar
    Las Vegas
    138
    08:55 PM
    Robin, I did what you stated above a few years back when I had to do something similar. It wasn't too time consuming if you isolate the walls and select multiples at the same time. It also helped that I had already built my exterior walls on an EXTERIOR SKIN workset.
    I'd be interested if someone has come up with a different option to do this now that we have Dynamo.
    2,717
    02:55 PM
    You could also use a material schedules and as above, filter a parameter based on the view.
    There's a dynamo node 'is visible in view' (cant remember the exact node name) to do the filtering and all scheduling as well (maybe setup some working views for this with minimum view depth).
    Then write to excel as a full custom format take off for the whole building.
    We do something similar for our area schedules.
    Last edited by elton williams; January 25th, 2020 at 12:23 PM. Reason: Carnt spel werds
    4,435
    04:55 AM
    We employ a workflow using a Dynamo script I built that quizzes our (curtain) wall vectors then establishes they're perpindicular (facing) orientation, respective of (true) North then push-populates said values to custom SP to them, and all curtain panels within each, to be reviewed by coloured-in (by filter) views, schedules, and on one showy-off job, via a PowerBI report...
    BUT
    that's our way of modelling exteriors - near exclusively - using curtain walls over basic walls.
    We found (area) values extracted from basic walls, however done and compensated for, simply weren't close to accurate enough for useful takeoff. Essentially, as soon as we respect the fact basic walls are calculated as lines, (and not always along their centres, when considering the different placement methods) then accounting for their thicknesses and auto-joining/healing behaviours, whilst (arguably) negligble, the numbers don't add up.
    BUTT
    Even our method's not perfect, by any means, apart from being dependant on strict adherence to a specific modelling method - and chronic slow (to run the script) it also raises (more) questions -
    https://twitter.com/snowyweston/stat...12679136378881
    that we've so far not answered.
    Last edited by snowyweston; January 26th, 2020 at 05:38 PM. Reason: thought I'd add a piccy
    2,738
    09:55 PM
    How far off did you find the numbers between the two systems?
    I use a similar script to determining areas for ComCheck.
  1. Make elements visible thru other elements (like walls) in an elevation
    By engineer in forum Architecture and General Revit Questions
    Last Post: February 16th, 2018, 02:27 PM
  2. Area Schedule Subtoals and Grand Totals
    By krickabaugh in forum Architecture and General Revit Questions
    Last Post: January 26th, 2017, 04:02 PM
  3. Revit OpEd: Tagging Elements and their Area
    Last Post: October 23rd, 2013, 04:15 PM
    Last Post: August 28th, 2012, 01:45 AM
    Last Post: August 16th, 2012, 01:45 AM
