Thread: Move multiple structural rebar tags
    November 13, 2017
    04:05 PM
    Is it possible in Revit to Move multiple structural rebar tags at once but that leader end stays on same place??
    I tried approach of setting leader with "Attached End" but when i choose this option leader end moves from target like in the picture below.
    December 11, 2010
    Astana
    227
    09:05 PM
    Try BIM42 Align plugin (free) and Free End option.
    2,780
    01:05 AM
    I love that plugin but unfortch no v2020 yet.
    November 13, 2017
    04:05 PM
    Unfortunately BIM42 Align doesnt do what i want
    December 11, 2010
    Astana
    227
    09:05 PM
    FYI trick from the Adsk app store:
    "Until I found this solution to get it work in 2020. I copied from here "C:\ProgramData\Autodesk\ApplicationPlugins\BIM 42 Align.bundle\Contents\Sources" this 2 file: "AlignTag" and "AlignTag.dll" to this folder "C:\ProgramData\Autodesk\Revit\Addins\2020".Now for me it's working fine with Revit 2020."
    Quote Originally Posted by krkec View Post
    Other options:
    Pinned rebar tag + Attached End (the leader will follow the host bar)
    Multi Rebar Annotation
    Member byk3bep's Avatar
    January 30, 2014
    453
    05:05 PM
    Multi rebar anotatation all for rebar elements that are showing in section, and Tag for those seen in projection.
    No addins used for the attached pfd, just some custom tag families.
    New Member Samohive's Avatar
    April 28, 2020
    665 Union Avenue Holtsville, New York 11742
    03:05 PM
    Quality Aircraft parts and Accessories repairs, overhauls, and exchanges aircraft parts and general aviation accessories. Explore the aircraft parts selection today!
  1. Pipe/Duct Tags Move when Offset is Changed?
    By evan.dodds in forum MEP - General
    Last Post: January 22nd, 2016, 01:31 AM
  2. modifying structural rebar
    By AaronCar in forum Structure - General Questions
    Last Post: October 1st, 2015, 11:24 AM
  3. Can an architect move the structural model components?
    By Meitnerium in forum Architecture and General Revit Questions
    Last Post: April 28th, 2015, 08:55 PM
  4. Multiple Language Tags
    By Tim West in forum Architecture and General Revit Questions
    Last Post: February 28th, 2013, 01:34 AM
  5. Rebar tag with multiple label parameters
    Last Post: February 6th, 2013, 10:05 PM
