Thread: Duct Transition Area Formula. Please Help!!
    January 31, 2020
    10:11 PM
    Afternoon Peeps,
    I'm trying to add a formula for working out the area of square to square duct transition. I've added the Area Parameter and now i can't get the formula to work??
    Here it is:-
    (Duct Width1 * Duct Height1 + Duct Width2 * Duct Height2)*Duct Length
    It keeps coming up with inconsistent units
    Is this even right way to calculate a transition??
    Please help! Thanks in advance
    December 11, 2010
    Astana
    206
    06:11 PM
    January 31, 2020
    10:11 PM
    Yep still going over my head
    read this thread first https://revitforum.org/showthread.ph...=units+formula[/QUOTE]
    December 11, 2010
    Astana
    206
    06:11 PM
    In your case Revit calculates units in this way:
    (mm * mm + mm * mm)*mm = (mm + mm)*mm = mm
    If you divide the expression by 1 mm, you get mm squared:
    mm / 1 mm = mm
    i.e. full formula::
    (Duct Width 1 * Duct Height 1 + Duct Width 2 * Duct Height 2) * Duct Length / 1 mm
    January 31, 2020
    10:11 PM
    Thanks so much!
  1. Duct Riser Symbol at transition
    By evan.dodds in forum MEP - General
    Last Post: May 24th, 2019, 08:31 PM
  2. Duct connector causing formula to allow wrong answer?
    By jturovskiy in forum MEP - Family Creation
    Last Post: April 17th, 2019, 11:14 AM
  3. Area For DUCT ELBOW
    By Dhilip in forum MEP - General
    Last Post: March 15th, 2018, 04:50 PM
  4. Tap into a duct transition?
    By Traxfsih in forum MEP - General
    Last Post: May 28th, 2014, 08:42 PM
  5. Schedule Formula for Existing area
    By koreyd77 in forum Architecture and General Revit Questions
    Last Post: May 23rd, 2013, 02:28 PM
