Thread: Structtual engineering
    February 3, 2020
    0
    10:08 PM
    What is meant by structural failure?
    1,534
    12:08 AM
    A collapsing building in most cases.
    "I am NOT a Revit tutor!"
    Dave Jones's Avatar
    4,560
    03:08 PM
    Quote Originally Posted by janesyd View Post
    the failure of a structural member due to external forces...
    July 26, 2019
    DFW, Texas
    56
    05:08 PM
    In the grossest sense, it's any failure of a structure to meet expected/reasonable design goals.
    More typically, it's a miscalculation/omitted calculation/flawed assumption in a complex assembly.
    It can also be a miscommunication of design intent to a builder.
    If the structural engineer, for instance designed a monolithic multi-arch concrete structure and properly calculates all of the linear forces and moment, but fails to check lateral forces, that could be a structural failure (even if the structure does not fall down).
    The latter case is more vexing. Let's say a tube section is required, and the design calls for two "C" sections to be welded together with the welds along the horizontal axis (flange to flange), and the builder welds them along the vertical axis (webs become flanges) this can create a major structural failure (especially if the tube section is meant to be bored for continuous all-thread rods to be passed through vertically).
    It can be complicated, too. A 3" thick slab of poured-in-place 3000psi concrete might be perfectly adequate, unless the subgrade below that slab was junk.
    Wellington, New Zealand
    717
    11:08 AM
    My previous marriage?
    1,534
    12:08 AM
    3 Not allowed! Not allowed!
    Quote Originally Posted by Alex Page View Post
    I think he asked about structural failures not train wrecks
    717
    11:08 AM
    harsh man!
    (harsh but true)
  1. RTC: Engineering*BILT just for you
    By RTC in forum Blog Feeds
    Last Post: July 5th, 2018, 05:15 AM
  2. how create family for engineering
    By philsogood in forum MEP - General
    Last Post: April 16th, 2017, 06:20 PM
  3. Reverse-engineering Trig.
    Last Post: August 20th, 2013, 03:39 PM
  4. IT Engineering in BIM
    By jrich in forum MEP - General
    Last Post: August 9th, 2012, 08:03 AM
