Results 1 to 10 of 14
Thread: Family "XX" is corrupt and its instances cannot be updated.
    September 21, 2016
    Boston
    228
    12:05 AM
    I am frequently getting this message when I select a family in my project and change the type:
    Family "xx" is corrupt and its instances cannot be updated. Please reload the family to repair the project"
    It's disrupting my work flow and i am worried it could mess up my model. Any reason this may be happening and how to fix it?
    Senior Member Darius's Avatar
    May 6, 2013
    502
    11:05 PM
    https://revitforum.org/showthread.ph...ecome-unusable
    check out this thread
    see if the behavior described matches what is happening for you
    September 21, 2016
    Boston
    228
    12:05 AM
    Yes, this is happening to me as well
    March 5, 2011
    Southern California
    673
    08:05 PM
    4,435
    04:05 AM
    not exclusively 2020 though (we've seen it in 2019.2.2)
    July 7, 2017
    Hernando, MS
    565
    10:05 PM
    Does this issue cause families to disappear from the model with no warning whatsoever? Or is it always generating these family corruption messages?
    We have a project that seems to have some elements disappearing, but without warning. I think it's related more to new vs. existing elements, some things getting demolished, etc. that's causing certain families hosted by those elements to disappear. But I wanted to be sure.
    10,796
    10:05 PM
    Quote Originally Posted by PatrickGSR94 View Post
    Nothing disappears "without warning." However: A warning pops up about Types being corrupt. If the user clicks the wrong option in the Error Message, then tons of stuff gets deleted and pretty damaged.
  8.    #8
    July 7, 2017
    Hernando, MS
    565
    10:05 PM
    so if we're not seeing these corrupt error messages then we're probably okay, right? I haven't seen it yet in this office, but we pretty much started using 2020 on the 2020.2 build as of Jan 1 of this year.
    I just opened the project in question with Audit ticked and it found no issues.
  9.    #9
    3,194
    10:05 PM
    3 Not allowed! Not allowed!
    If you jumped directly from 2020.0 to 2020.2, you should be good.
    The corruption happens when a project is upgraded from an earlier Revit to 2020.1 and then used in 2020.2
    If you want be sure, do an Audit when opening the project.
    Then check your Journal for a line like this
    ' 3:< [Baluster - Square], LoadedId = 64008, GUID = 8b93f594-7c1e-4760-9e3a-24a3880c4233, refers to a NON_EXISTENT_CONTENT_DOC. Please reload!
    There are several other "reload"s in a Journal file, but the "NON_EXISTENT_CONTENT_DOC" phrase is unique to this bug
    Also, the hotfix was released today. Check your Autodesk Account page
    https://help.autodesk.com/view/RVT/2...20updates_html
  10.    #10
    July 7, 2017
    Hernando, MS
    565
    10:05 PM
    okay thanks, we went straight from 2019.3 to 2020.2, so hopefully we're good.
  1. Putting "Z" value to family instances
    By Chris Needham in forum Dynamo BIM
    Last Post: November 15th, 2019, 03:07 AM
  2. Replies: 2
    Last Post: April 12th, 2016, 09:06 PM
  3. "Element's internal join data is corrupt." - What's that all about?
    By Stuntmonkee in forum Architecture and General Revit Questions
    Last Post: January 12th, 2012, 07:56 PM
  4. warning message of "There are identical instances in the same place ..."
    Last Post: December 8th, 2011, 10:32 PM
