Thread: How to make courtain grid out of a custom mesh?
    February 6, 2020
    08:15 PM
    Hi! My master project has this custom glazed roof of irregular shape. Underneath there is a structure so the mesh had to be customized in sketchup in order to match. I then imported it from skp as a mass. Now I Wonder if there is a way to make mullions and pannels out of this grid? Do you have any idea? Would be thankful!!! I'm attaching a pic of it.
    Forum Addict Andres Franco's Avatar
    June 21, 2012
    Tours, France
    1,103
    08:15 PM
    Hi remi_c, it seems doable by using a mass family dividing the surface of the mass as desired in the family editor , finally for the panels you need to use some adaptive panel family, sere the video i'm attaching here, maybe you'll find some useful examples, regards
    https://www.youtube.com/watch?v=cXGq4sGK66I
    February 6, 2020
    08:15 PM
    Thanks for answer. Solved it. I had to make courtain system, select all faces and set division on both axis to 1 (no division). It's a bit primitive but worked for me...
    June 21, 2012
    Tours, France
    1,103
    08:15 PM
    Quote Originally Posted by remi_c View Post
    Thanks for answer. Solved it. ... worked for me...
    Glad to know that the problem is solved, best regards
    February 13, 2020
    07:15 PM
    Thanks for the information.
    Last Post: December 12th, 2018, 12:15 PM
  2. super custom curtain wall grid
    By atis in forum Architecture and General Revit Questions
    Last Post: September 12th, 2015, 10:38 PM
  3. Custom Grid heads
    By kescr in forum Architecture and General Revit Questions
    Last Post: October 1st, 2014, 01:55 PM
  4. Building Coder: ADN Mesh Data Custom Exporter to JSON
    By Building Coder in forum Blog Feeds
    Last Post: July 11th, 2013, 10:15 AM
  5. custom grid problem
    By mlegs in forum Architecture - Conceptual Massing and Adaptive Components
    Last Post: May 31st, 2011, 09:29 PM
