Страница 1 из 2 12 ПоследняяПоследняя
Показано с 1 по 10 из 12
Тема: How to cut out parametric objects
    Регистрация
    07.01.2020
    Сообщений
    9
    Местное время
    22:42
    Hello Guys,
    Can someone quickly give me a clue on how to cut out parametric objects in revit family creation...its a pain in the Ass!
    I intend to cut it in 3 Areas as shown in the diagram.
    Thanks in Advance
    Миниатюры Миниатюры Нажмите на изображение для увеличения
Название: Family objects.PNG
    Forum Addict Аватар для Andres Franco
    Регистрация
    21.06.2012
    Адрес
    Tours, France
    Сообщений
    1,116
    Местное время
    22:42
    Hi Iyke29, as far as I can see on your image you'll can cut those by putting some voids and by attach them using reference planes, seems not complicated at all! regards
    Forum Co-Founder Аватар для Alfredo Medina
    Регистрация
    07.12.2010
    Адрес
    Сообщений
    3,228
    Местное время
    17:42
    Can't you model that as a single extrusion with that shape, without cutting anything?
    Регистрация
    19.02.2017
    Сообщений
    19
    Местное время
    00:42
    -1 Not allowed! Not allowed!
    You need to make a face based void family and then call it in your desired family and put it on the face you want.
    Регистрация
    07.01.2020
    Сообщений
    9
    Местное время
    22:42
    Yea, thanks guys if finally did it using the voids command, i encountered yet issue with the concrete floor that should come right on top of the foundation. It has several slanted points meant for drainages, how do i model this several high points and lower points. Thanks in advance guys....sorry i am new with using revit ....just couple of months old....say 6 months
    Регистрация
    21.06.2012
    Адрес
    Tours, France
    Сообщений
    1,116
    Местное время
    22:42
    Цитата Сообщение от Iyke29 Посмотреть сообщение
    ....It has several slanted points meant for drainages, how do i model this several high points and lower points...
    Hi Again, you need to edit your slab "sub elements", to do that you pick the slab then on the ribbon you'll find an option called "modify sub elements" this allow you to add individual points or lines which can have different heights, those heights can be controlled by a grip or by entering a value, hope this helps
    Регистрация
    07.01.2020
    Сообщений
    9
    Местное время
    22:42
    Hello Franco,
    Thanks alot for the quick reply but what you said is correct but i still have difficulties to adjusting the bottom because the points are on top. see attached images..Нажмите на изображение для увеличения
Название: under height.PNG
    i await your response .....
    Регистрация
    21.06.2012
    Адрес
    Tours, France
    Сообщений
    1,116
    Местное время
    22:42
    Hello Franco,
    Hi again Iyke29,
    I understand your issue, in your case is still doable by using a void to cut the floor, you'll need to do as follows:
    1. Create a Reference plane and name it (the reference plane is necessary to define the plane to create the void extrusion which will cut your slab)
    2. Create an in place Void component and put it in the Floor Category
    3. Create your extrusion and by hitting the cut button cut your slab with your void (See images)
    I guess that's all you need to cut your slab, regards
Название: Void Floor Cut.JPG
    Последний раз редактировалось Andres Franco; 07.02.2020 в 09:39.
    Регистрация
    21.06.2012
    Адрес
    Tours, France
    Сообщений
    1,116
    Местное время
    22:42
    Even if this is possible I find that is unnecessary since you can do the same without having a nested family!
    Forum Addict Аватар для elton williams
    Регистрация
    07.12.2010
    Адрес
    Сообщений
    2,753
    Местное время
    07:42
    Isn't this whole process better off just using slab edges?
Похожие темы
  1. Remove objects from a model, but retain those objects for other use
    от NotSoMuch в разделе Architecture and General Revit Questions
    Ответов: 5
    Последнее сообщение: 10.10.2018, 18:28
  2. Outlines on 3D objects
    от TomLane37 в разделе Architecture and General Revit Questions
    Ответов: 1
    Последнее сообщение: 17.07.2018, 14:57
  3. How to get double placed objects?
    от andreasdraxl в разделе Dynamo BIM
    Ответов: 4
    Последнее сообщение: 13.06.2018, 14:53
  4. Is Revit a Parametric Designing software Or simply a Parametric Drawing one?
    от smshiran в разделе Architecture and General Revit Questions
    Ответов: 2
    Последнее сообщение: 18.11.2012, 10:48
  5. Parametric Circular Objects
    от cellophane в разделе Architecture - Family Creation
    Ответов: 27
    Последнее сообщение: 14.11.2011, 01:26
Ваши права
  • Вы не можете создавать новые темы
  • Вы не можете отвечать в темах
  • Вы не можете прикреплять вложения
  • Вы не можете редактировать свои сообщения
