Results 1 to 6 of 6
Thread: Acquire Shared Coordinates from Navis
    3,297
    01:34 AM
    We have a client that wants us to use their Shared Coordinates file.
    Normally, not a problem.
    However, all they have is a Navisworks file.
    I know we can publish SCs TO a Navis file, but is it possible to acquire our Revit SCs FROM a Navis file?
    January 19, 2012
    347
    01:34 AM
    In Navis I would turn on the Coordinates display & the Compass, then in Revit Set Coordinate at Point from a designated reference point in Navis.
    3,172
    11:34 PM
    Not that I'm aware of. They can't define "shared coordinates" in Navis, they can only append files that been prepared with some agreement on location. Something else defined the coordinates they want to use.
    11,040
    01:34 AM
    Why cant they just give you a known coordinate from a fixed point in the file (grid intersection), and give you the angle to true north?
    A lot of folks act like Shared Coordinates are this nebulous thing that has to be transmitted file to file. People forget its just a rotation amount and a coordinate value.
    Forum Addict tzframpton's Avatar
    January 17, 2011
    2,104
    01:34 AM
    Right click on the file in the Selection Tree and click "Units and Transform" and view the coordinate readout. That's a place to start, but can't remember if the readout shows rotation angle. And that's assuming it's never been manipulated.
    I don't know if this "is" how you acquire this info "from" Navis, but I do know it relates to something from Revit and Revit's coordinate system (which one I do not know). Going off memory BTW, I may be wrong in my direction. I can open Navis later and confirm.
    -TZ
    May 18, 2011
    Calgary, AB
    437
    12:34 AM
    Would this not assume that the original authored model used "shared coordinates" to begin with?
    I've never dug into if project coordinates and shared coordinates (if assigned) are both there in Navis. My gut says it's one or the other and it would depend on export.
  1. Acquire Shared Coordinates from Point Cloud file
    By paidpal in forum Architecture and General Revit Questions
    Last Post: November 11th, 2018, 06:29 PM
  2. Acquire Coordinates - Model and link share same coordinate system allready
    By sdbrownaia in forum Architecture and General Revit Questions
    Last Post: April 27th, 2018, 10:01 PM
  3. Site Setup - Acquire Coordinates vs. Specify Coordinates at a Point
    By Mel in forum Architecture and General Revit Questions
    Last Post: September 7th, 2016, 11:03 PM
  4. Revit OpEd: Confirm Acquire Coordinates
    By Revit OpEd in forum Blog Feeds
    Last Post: October 31st, 2014, 03:15 PM
  5. Question: 'Acquire Coordinates' Command Does Nothing
    By truthjusticeUSAway in forum Tutorials, Tips & Tricks
    Last Post: December 17th, 2013, 02:58 PM
