Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Door family strategy
  1. #11
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    166
    03:40 AM
    It's not more error free. LOL.
    I've seen manufacturers doors, before. We don't have to agree. Was just chiming in to point out that MOST folks aren't going to succeed using manufacturer stuff.
    Like I said, if you are happy with it... Great!
    They are useless, where I'm from... And in every country that I work in.
    Im interested in your manufacturer doors, can i download them somewhere?
    Here are 2 examples of the doors we use here.
    And i have made my own door family's once, for wooden doors witch we make ourself in the workshop.
  2. #12
    11,261
    08:40 PM
    Can you download ours? No.
    The point is,they can represent many manufacturers doors. Show me a manufacturers cut sheet (not a Revit family. I don't care about those) that you think (for some reason) can't be shown by a non manufacturer family, ND I'll show you a screen shot that says it can.
  3. #13
    January 15, 2020
    The Netherlands
    166
    03:40 AM
    For the doors i meant the manufacturer doors you discribe as terrible. was just curious to look at them.
    Im not trying to prove to you thaot mat you can make the manufacturers doors yourself. But that its way better to just use the models they provide. Since the door familys are pretty good where i live, it saves us a lot of time just taking the manufacturers models. Also they have more manufacturer specific information in them. when working towards BIM models, thats an important factor.
    I tend to use my own generic models where theres not that much information needed, and only a location.
    Sure i could make my own door familys, you would just need to make it so the dimentions are linked to a manufacturer parameter you can select in the family. otherwise you would be editing a lot of parameters every time you use the doors.
    Here are a few doors witch are most common where we live:
ID:	38302Click image for larger version.
ID:	38303Click image for larger version.
    And just to make clear. im not trying to argue with you, just curious.
  4. #14
    11,261
    08:40 PM
    I'm not new at "working towards BIM." Having all the junk that manufacturers put in their families as "data" does not make their families more useful or valuable than a custom built generic door family with parameters alterations to match a specific door.
    And yes: Looking at those cut sheets, our non-manufacturer doors could represent both of those, in less than five minutes of parameter adjustments.
    There is nothing special about those doors requiring a custom family.
  5. #15
    January 15, 2020
    The Netherlands
    166
    03:40 AM
    Well sure, but i have better ways to spend my time at work than to create something that has already been done. If i would make those family's they would most likely be worse anyway.
    And just to be clear, our doors are not like the familys found on websites like bimobject witch have 300 text shared pamameters saying the same thing. They are as clean as my own familys. But its still nice to have more info on what kind of profile is used ect..
  6. #16
    11,261
    08:40 PM
    You spend the same (or more) time digging through manufacturers sites to find those doors,than I spend editing parameters (not editing families) to make.it represent that doors.
    Regardless, we don't have to agree.
    *I* recommend the OP not waste their time on manufacturers doors. Hence, I outlined a proven strategy for building doors. I can guarantee we spend less time managing and using doors, than it would take to hunt down manufacturers items, and then get them all to schedule correctly.
    We're just polluting the thread now. Have fun with your manufacturers doors, and I'll have fun without them. Said my piece, already.
  7. #17
    November 2, 2011
    Slaithwaite ("Sla wit"), W Yorks, UK
    275
    02:40 AM
    I'm not going to argue that good manufacturer's BIM content can't be found if you look hard enough, but my experience over many years in this game bears out what Aaron is saying. As a general rule, I've found that manufacturer's content is not great and much of it is absolutely abominable. It is almost always preferable to craft your own or find a good independent generic source.
    Even when you do find something that, on the face of it, appears usable there is a high chance that at some point that you will need to modify or replace it with another manufacturer's version. Both of these bringing many potential issues.
    Case in point - I had just one sectional overhead door on a project, but the manufacturer finally chosen by the contractor did not produce BIM content. I found an alternative that seemed close enough and used that. Came time to issue the as-constructed data and the overhead track position in the model did not correspond to the position in the point cloud survey by 128mm. The contractor insisted that this was corrected and rejected our model. It was the only correction required in the architectural model for as-constructed state! But the family that I had used was so complex and formula driven that there was no way to unpick what was driving the track position without breaking the model. I wasted hours trying to achieve the required result before giving up and modelling a new family from scratch. Exactly what I should have done all along...
  8. #18
    November 18, 2016
    196
    02:40 AM
    Quote Originally Posted by john.warburton View Post
    well bloody done!!!! We dont even entertain the idea of doing "as constructed models" (mainly because we dont agree with what's been built in a lot of cases!!) however if that was the only change you've done a brilliant job!!
  9. #19
    August 19, 2011
    New Hampshire
    524
    09:40 PM
    What Aaron said in his first post is generally what all door content should eventually be.
    The hardest thing about using manufacturer door content is that there is no 'one way' to develop certain kinds of revit content. Everybody has different needs and wants, and some manufacturers get too focused on certain aspects and forget to improve others. I know when I was doing work with some clients, I knew in the back of my head that what I was putting out was at least workable, or at most salvageable, but was not going to meet all the needs of every user.
  10. #20
    November 18, 2016
    196
    02:40 AM
    2 Not allowed! Not allowed!
    and this is what it boils down to IMHO. if manufacturer stuff meets your needs (and the end user) then fine. If creating your own family meets your needs then fine. There isnt a one-size fits all answer, most people will find a bespoke family is best for them but there is certainly a market out there for manufacturer created families especially if they get scheduled out via COBie and you need to include manufacturer parameters anyway.
  1. RTC: Technical or Strategy?
    By RTC in forum Blog Feeds
    Last Post: October 4th, 2018, 01:15 AM
  2. Converting a door family to a curtain wall door
    By DavidLarson in forum Architecture - Family Creation
    Last Post: September 1st, 2017, 10:45 PM
  3. No rooms in door schedule unless door family has Room Calculation Point
    By mgjp in forum Architecture and General Revit Questions
    Last Post: June 12th, 2017, 11:07 PM
  4. MEP modeling strategy
    By ari.monteiro in forum MEP - General
    Last Post: April 10th, 2015, 11:51 AM
  5. Door Family: Can I have nested door panels with different driving parameters?
    By rpester in forum Architecture - Family Creation
    Last Post: October 28th, 2013, 05:04 PM
