Thread: My Formula isnt working Properly.
    September 26, 2019
    11:44 AM
    I am trying figure out what the issue is with my formula.
    IF(Height>96", (15'-(Height+6")),
    IF((Height/2)>2', 8',
    IF((Height/2)<2', 15'-(5'+(Height/2), Height +2"))))
    The Dialog that I am receiving is " Comma not expected." However, I am not sure what comma is extra as I have tried to remove one by one.
    I was hoping someone here could help me.
    Thanks in advance!
    January 15, 2020
    The Netherlands
    87
    07:44 PM
    Your getting this error with all those formula's?
    The middle one is missing a '')'' on the end.
    The top one needs that comma at the end removed and another '')'' put there
    Or is it all 1 formula?
    3,228
    01:44 PM
    3 Not allowed! Not allowed!
    Quote Originally Posted by Modderhoop View Post
    I understand that it is all one formula.
    These are the issues I see:
    • For clarity, instead of writing (Height/2) <2' , you could write simply Height/2 > 2' ; it is the same but without two unnecessary parenthesis.
    • For clarity, it is better to keep the same format for the numeric values, such as all in inches.
    • For clarity, instead of writing Height/2 > 2' , you could write Height > 48". Same but simpler.
    • The parenthesis that begins before 5' was not closed, and that caused a confusion with the commas.
    • The formula needs 2 IFs statements only, not 3. The last part of the formula, Height +2" , has no chance to happen, because your third IF is the opposite of your 2nd IF. You wrote: if Height divided by 2 is greater than 2 do this, and then you added the opposite condition in the third IF: if Height divided by 2 is less than 2', do that. Instead of adding a third IF, simply write the "otherwise, do this" part.
    In summary, as per the above comments, the formula could be like this:
    if(Height > 96", 180" - (Height + 6"), if(Height > 48", 96", 180" - (60" + Height / 2)))
    If Height is greater than 96", do this. Otherwise do this: if it is greater than 48", do this, otherwise, do this.
    Hope that helps.
  1. My Lookup Table is not Working Properly?
    By khorn06 in forum MEP - Family Creation
    Last Post: January 6th, 2019, 01:49 PM
  2. Sealant Bead Not Working Properly
    Last Post: August 9th, 2018, 08:00 PM
  3. horizontal angle is not working properly
    By deepu in forum Architecture and General Revit Questions
    Last Post: November 18th, 2017, 04:44 AM
  4. Not Sure Why Script Isnt Working
    By Bdcoll in forum Dynamo BIM
    Last Post: January 21st, 2016, 12:36 PM
