Thread: Window Family Display Issues
    January 2, 2015
    25
    02:50 AM
    I created a window family with multiple material parameters. Frame and Sash of the window is one material and then I painted a parameter material on both the interior and the exterior of the window geometry. This allows our window schedule to actually list the frame material and the finishes separately. I made three separate families this way, and have the same issue with all three of them. (links attached to download).
    Well when I look at the family in section, it doesn't seem to show up correctly. The interior and exterior painted parameters work fine, but frame/sash material doesn't display correctly on the sash. But it does display correctly on the frame. Another wrinkle is that it also displays correctly when cut in plan.
    Any ideas would be greatly appreciated!!
Name:	Window in Plan.JPG
ID:	38298Click image for larger version.
Name:	Window in Section.JPG
    https://tmsarchitects.sharefile.com/d-s85330bd11ca40c29
    Senior Member Darius's Avatar
    May 6, 2013
    501
    03:50 AM
    do u have any wraping on any of these?
    January 2, 2015
    25
    02:50 AM
    Quote Originally Posted by Darius View Post
    The walls have no wrapping at inserts or wrapping at ends. I'm also not sure what that would do with the section cut of the window.
    10,875
    02:50 AM
    Humor me, in a test file: Switch the Window to Generic Model, and load it back in. Does it work then?
    January 2, 2015
    25
    02:50 AM
    That actually made it worse. Now it was displaying "wrong" in plan as well as in section.
    10,875
    02:50 AM
    Quote Originally Posted by JayDub View Post
    Hmmm. Are the sweeps four sided (running around the entire perimeter of the window), or are they individually built, on the four sides?
    My guess is you are seeing the back side of them, in section, because of the lack of cutability in the Window families.
    January 2, 2015
    25
    02:50 AM
    Well what's weird about it is that half of the geometry is cut correctly and the other half is not. The window frame (shown as orange) is a 3 sided sweep and display's as it's supposed to. The sash of the window is a 4 sided sweep, but does not show as cut.
    And if I cut a section view in the family itself and set it to "preview" it displays how I would expect it to.
    10,875
    02:50 AM
    Yeah. As im sure youve discovered: Section view in the family and section view in the project = not the same thing, unfortunately.
  1. Revizto Display Issues
    By tzframpton in forum Coordination Tools
    Last Post: July 27th, 2018, 04:18 PM
  2. Window Family Does not display correctly in Legends
    By Rwright in forum Architecture and General Revit Questions
    Last Post: October 20th, 2016, 05:40 PM
  3. Window family - strange display artefact
    By Alecsx in forum Architecture and General Revit Questions
    Last Post: May 26th, 2015, 12:58 PM
  4. Display issues in MEP!!
    Last Post: April 12th, 2013, 04:03 PM
  5. Possible display issues in 2013
    By Madelien in forum Architecture and General Revit Questions
    Last Post: February 25th, 2013, 01:47 PM
