Results 1 to 10 of 11
Thread: Revit 3D model- precast walls
    February 10, 2020
    04:00 PM
    Hello,
    I have question about creating 3D model in Revit Structure based on precast construction. The main parts of the model are walls. Walls have three layers: concrete- thermal insulation- elevation. Between conection of each wall is 1cm empty space. As you can see on including picture (part of a building) each wall have very specyfic shape and sometimes conection between each other. The elevation part of walls have different size in each wall (there is different distance between elevation and concrete part- both vertica and horizontal). Both concrete and elevation have reinforcement. Do you think that it is possible to make 3D structure model based on this construction and than reinforce it or even if not, is it possible to make just 2D construction drawing from this created model? And if it is possible how to start modeling? Just by using basic tools, or families/ Dynamo?Click image for larger version.
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    267
    03:00 PM
    I always draw walls as seperate walls.
    So concrete would be a wall, and isolation would be a different wall.
    If you do it that way it is easy to make your prefab concrete elements, and put rebar in them later.
    1,686
    05:00 PM
    Quote Originally Posted by Marcel Jansen View Post
    Yep me too. It does have a few more benefits too, like being able to easily have different wall heights without the need to mess with that offset thingy (or whatever it is called) and easier to exchange them when you get a model from the structural guys too.
    February 10, 2020
    04:00 PM
    So you mean that the easiest way is to create building model by using 3 different parts: inside wall 1: concrete, in the middle wall 2: isolation and outside wall 3: elevation. And all that parts will be separated from each other? Am I right?
    December 25, 2011
    The Netherlands
    267
    03:00 PM
    Yes yes
    1,686
    05:00 PM
    It sounds like more work, but in the end it is much easier do split them all up. Another benefit is that calculations are a bit more accurate as well.
    Revit calculates on the baseline of the wall for m2 or m3 and with the wall separated into 3 (or more) layer the numbers become better too.
    February 10, 2020
    04:00 PM
    Ok. Thank you very much.
    I have one more question about this specific precast walls shape and join between each other (picture). I want to make model with possibility of reinforcing this shape of walls in next step. Do you know is it possible?
    1,686
    05:00 PM
    If it is that detailed I would probably go with srutuctural framing. Much easier to reuse types and make schedules. And you don't have the issue of walls cleaning up when you don't want to.
    December 25, 2011
    The Netherlands
    267
    03:00 PM
    Make sure you click the ends of the wall and set them do ''disallow join'' on both sides. After that just edit the wall just the way they will make it.
    After you made these you can make assemblies of it, and make shopdrawings.
    If you will need to make these a lot of times you can also buy some plugin from AGACAD for prefab concrete.
    http://www.aga-cad.com/products/pack...ecast-concrete
    April 10, 2020
    4
    10:00 PM
    hi Mileq,
    can you expain for me about your wall? when i do insulation wall by precast. i use 1 famiy wall have 3 layer 1 concrete 1 insulation then 1 concrete. then when i do shop ticket i use model for doing ticket.let me know how you do shopdrawing?
    Thank
    Canh
  1. Revit Precast
    By m_qbp in forum Third party Add-Ins, API and R&D
    Last Post: April 10th, 2020, 07:31 AM
  2. Anyone using the stair tool for precast concrete stairs or generic model families?
    By Andrew P in forum Architecture and General Revit Questions
    Last Post: June 2nd, 2015, 01:23 PM
  3. Linked Arch Revit Model - View Another Floors Walls
    By MartinGT in forum Architecture and General Revit Questions
    Last Post: October 30th, 2014, 12:14 PM
  4. Precast Floor problems when trimming shape of precast
    By ryntau in forum Structure - General Questions
    Last Post: December 9th, 2013, 12:01 PM
  5. Analytical model and slanted walls
    By jbenoit44 in forum Structure - General Questions
    Last Post: October 10th, 2012, 08:28 PM
