Thread: Detail Components in Profiles Don't show Fill Pattern
    December 20, 2010
    1,113
    10:10 AM
    Is this a known issue? When I embed a detail component into a profile, then use that in the project none of the fill patterns of the detail component show thru. Is there a fix for this?
    3,228
    10:10 AM
    Hi, Scott. I made a test, using 2018.3.3. This works correctly in a wall sweep that is part of the properties of a wall, or in a wall sweep that is placed on a wall, or in fascias or gutters. It might work in other sweeps, too. It does not work the same for model in-place sweeps But you could edit the model in-place and add the detail item family at the same workplane of the profile of the sweep. Also, you could add a material to the model in-place sweep.
  1. Revit 2018 2-D family detail line components for Steel Roofing profiles
    By RichardM in forum Third party Add-Ins, API and R&D
    Last Post: August 23rd, 2019, 12:02 AM
    Last Post: January 8th, 2014, 10:15 PM
  3. What Revit Wants: Adaptive Components and Profiles
    Last Post: September 5th, 2013, 11:15 PM
  4. Shared Nested Detail Components in Line-Based Detail Components...
    Last Post: December 23rd, 2012, 04:27 PM
  5. wall type with fill pattern and colored fill
    By Ken Marcus in forum Architecture and General Revit Questions
    Last Post: December 30th, 2011, 10:25 PM
