Page 2 of 2 FirstFirst 12
Results 11 to 11 of 11
Thread: Simplifying your famlies with nested famlies
  1.    #11
    February 22, 2013
    362
    05:39 AM
    4 Not allowed! Not allowed!
    I got the idea from Josephpeel in this thread a couple years back:
    https://revitforum.org/showthread.ph...ications/page2
    It started off with me writing about using Piping System Schedules to schedule Text data for pipe material and insulation specifications, and he gave me the idea of scheduling images for the piping legends. There wasn't any magic to generating the images, all I did was take a screenshot from a PDF of our standard legend symbols and make small image files for each one. They key is to be VERY consistent in terms of the image height/width and line placement. I used Paint to put the text into each line symbol, making sure to use the same text font and height for every one.
Name:	Piping Legend.jpg
    And then from there I got the idea do this with other stuff. So I created a Multi-Category Schedule and started making images for every Type in our Standard families. Again, this involved a lot of work with Paint. But I'm happy with the result: I place a motor-operated damper or 3-way valve in the model and that image populates in the schedule on my cover sheet. This is a screenshot from our main template file, into which I've intentionally loaded every standard family we have. In an actual project, this would of course only reflect the objects that are in the model.
Name:	Mech Symbol Legend.jpg
    I also use parameters to filter these in/out of different versions of these schedules: for Mechanical only, for Plumbing only, and these, which are Mechanical and Plumbing combined. (On small jobs we combine the disciplines.) It took a while to set all this up but it works well. The Manage Images dialog box is crazy to scroll though, we have about 125 of these tiny images loaded, but it doesn't seem to impact model performance.
    Amusingly, the only reason I went to all of this effort was to appease our Quality Control manager, who is old school and extremely retentive. He was constantly marking up the legends for every job and I got sick of the markups. Now he has his customized legends tailored to every project and I don't have to spend time on all that BS drafting work.
  1. Building Coder: Simplifying Nested Family Instances
    By Building Coder in forum Blog Feeds
    Last Post: June 13th, 2018, 05:45 PM
  2. Replies: 0
    Last Post: March 16th, 2017, 04:15 AM
  3. Sticky Notes: Simplifying UK Level 2 BIM
    By Sticky Notes in forum Blog Feeds
    Last Post: July 1st, 2014, 10:15 PM
  4. Simplifying Finish Floors
    By irneb in forum Architecture and General Revit Questions
    Last Post: October 16th, 2013, 06:48 AM
  5. simplifying a topo surface
    By biff in forum Architecture and General Revit Questions
    Last Post: August 4th, 2011, 10:28 AM
