Thread: eTransmit with unexpected results
    May 14, 2012
    444
    05:11 PM
    I ran eTransmit today using some of the "Project Cleanup" tools ... except they didn't exactly cleanup as I expected. (The purpose of this exercise was to prepare the model for transmission to the GC's sub-contractors)
    The options selected were:
    - Disable worksets
    - Purge Unused
    - Include all sheets
    - and only views on sheets
    In the eTransmitted model, the walls disappeared from the plan, elevation, and section views (but not the RCP views). Creating new views revealed the walls were still in the model (plan, 3D, etc.). Also, the keynote schedules no longer respected the "filter by sheet" setting nor the sheet width setting.
Name:	eTransmit cleanup settings.png
ID:	38320Click image for larger version.
Name:	eTransmit walls disappear.png
ID:	38321Click image for larger version.
Name:	eTransmit keynote schedule.png
    I did some basic troubleshooting and concluded the wall issue occurred when using "Disable worksets" while the keynote schedule issue occurred with the "only sheets on views" setting. "Purge Unused" did not seem to have any effect (other than to purge unused families).
    While I have found a way to achieve the desired model results by using Purge Unused only and then manually deleting the views I don't want to include, I'm curious: Has anyone else encountered similar results when using these settings for eTransmit?
    10,780
    06:11 PM
    Quote Originally Posted by CADiva View Post
    - Disable worksets
    - Purge Unused
    By chance, do they have some worksets (like the worksets the walls are on) set to not be visible by Default? Ive seen weird things happen when that is the case, and Worksets were removed from the file. Seen it not just with eTransmit, but with regular DFC and Delete Worksets.
    May 14, 2012
    444
    05:11 PM
    Walls are on _Workset1 with the rest of the modeled components and are visible in all views. (And yes, I verified this in my initial troubleshooting.)
    There are a couple worksets set to be off by default (the furniture for instance), which is why the furniture appears on the floor plans once worksharing is disabled. I suspect this is one reason to not use worksets for visibility control.
    10,780
    06:11 PM
    Hmmm. Even though the walls arent on a workset thats off by default, id be curious to see if the problem still occurs if you set them to all be visible by default, before you eTran it.
    May 14, 2012
    444
    05:11 PM
    I set all the worksets to visible by default ... walls still disappeared.
    So I went through all the VT's and spot checked VG on views without VT's ... walls still disappear.
    Based on your earlier comment, I decided to see what happened with a basic DFC & Disable (vs eTran) ... and the walls disappear.
    10,780
    06:11 PM
    Ooooph. Thats freakin ugly!
    Interesting find. I would (seriously) file a Support Request, and send that one in. Id love to know whats causing that. I almost never use either option, so ive never seen it. (I just send the models with worksharing enabled, as they are).
  1. Unexpected Value Rounding with a Calculation Formula
    Last Post: October 24th, 2018, 09:52 PM
  2. Unexpected Revit Crashes
    By koolair in forum MEP - General
    Last Post: June 25th, 2015, 07:58 PM
  3. unexpected shutdown while opening revit
    By starkdesign in forum Architecture and General Revit Questions
    Last Post: September 2nd, 2013, 08:24 PM
  4. some unexpected things
    By gaby424 in forum Out There
    Last Post: August 24th, 2012, 11:29 AM
  5. Revit Clinic: Unexpected Quantities in Schedules...
    By Revit Clinic in forum Blog Feeds
    Last Post: July 12th, 2011, 08:40 PM
