Results 1 to 6 of 6
Thread: prevent revit plugins from installing/loading
    Forum Co-Founder iru69's Avatar
    United States
    1,663
    08:38 PM
    Hi all,
    I installed Bluebeam 2019 and it automatically is trying to install/load it's bluebeam plugin for Revit.
    I do not want the plugin.
    Every time I start Revit, it prompts if I want to load the bluebeam plugin. I see no way to disable this.
    Anyone know what to do?
    Thanks!
    Moderator mark b's Avatar
    NSW Australia
    1,436
    01:38 PM
    Has it loaded this .addin file ?
    "C:\ProgramData\Autodesk\Revit\Addins\2020\bluebea mAddin2019.addin"
    If so delete it or move it
    United States
    1,663
    08:38 PM
    Hi Mark,
    No, that file is not in that folder (and yes, I'm using standard Revit 2020). There are other addins, but nothing that starts with "bluebea..."
    I appreciate the reply... any other ideas?
    United States
    1,663
    08:38 PM
    After you suggested that, I did notice the load plugin dialog indicated it was trying to load the plugin from the bluebeam app folder, so I went and renamed the plugin.
    Now when I open Revit, it complains that it can't find the plugin. (so I renamed it back to its original name).
    NSW Australia
    1,436
    01:38 PM
    Top right on the bluebeam ribbon "Revu" scroll down to Administrator and in plugins deselect Revit.
    I tried it on Revit 2019 and seems to work, deactivates it.
    United States
    1,663
    08:38 PM
    Quote Originally Posted by mark b View Post
    Thanks, that did the trick!
    Kind of weird that there's no way for Revit to stop a rogue plugin though?
  1. Free Revit plugins by DiRoots
    By DiRoots in forum Third party Add-Ins, API and R&D
    Last Post: June 24th, 2020, 04:55 PM
  2. Prevent a link from plotting in Revit
    By zjanjua in forum MEP - General
    Last Post: June 9th, 2018, 06:14 PM
    Last Post: June 1st, 2015, 11:15 AM
  4. Plugins into Revit LT
    By IDN101 in forum Architecture and General Revit Questions
    Last Post: October 13th, 2013, 06:18 PM
  5. Revit plugins
    By bangobeat in forum Third party Add-Ins, API and R&D
    Last Post: September 20th, 2011, 09:39 PM
