Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Ensuring correct information shown at plot time
  1. #11
    Member tidalwave1's Avatar
    December 9, 2010
    Las Vegas
    138
    11:49 AM
    I have a life safety workset that is default not visible for the egress path generic model (pre-2020) because I only want it on in the life safety/egress plans (Area Plans). If there is a better way to manage this, I am open to ideas/changes in workflow.
  2. #12
    3,146
    11:49 AM
    View Templates could resolve that too. In my case I tried VT management first. It turned out they were using a lot of working views to get around view template's control. It wasn't my first choice but in this instance it worked.
  3. #13
    10,874
    01:49 PM
    Quote Originally Posted by tidalwave1 View Post
    There are better ways.
    Filters.
    Level of Detail.
    Line Based Detail Component instead of Line Based Generic Model
  4. #14
    May 14, 2012
    461
    12:49 PM
    Quote Originally Posted by GMcDowellJr View Post
    If you did use worksets for visibilty then you might use not visible by default.
    I've explained it using an example from our good friend AutoCAD.
    You're deep in a project with an xref in lots of files. You need to add a layer in the base file that you only want visible in one file and not in the other 99. If you turn it off/freeze it in the base file then simply opening, saving, and closing the 99 files will lock that layer state thanks to visretain and you only need to turn it on in the one file.
    Not exactly the same in Revit but, again, if you're using worksets for visibility and you add a workset late in the game, you can either update all of your VTs and/or views to hide it or set it to not be visible by default you only need to update those VTs and/or views you want to see it in.
    But yeah... don't use Worksets for visibility if you can help it... for lots of reasons.
    Quote Originally Posted by Steve_Stafford View Post
    I have used a workset set to Not Visible for point cloud links. In this case I don't want to see the point cloud in any views other than those (very few) I specifically decide to see them in. I opted for this because seeing the point cloud in all views was too painful. Otherwise, I really prefer they are visible by default.
    Yeah ... I basically did this on a recent project for exactly the reason you described. And as always, the shortcut came back to bite me, particularly when detaching & disabling worksets: https://revitforum.org/showthread.ph...pected-results. (Short version: walls disappeared in many sheet views ... not pretty if trying to print from them. The good news was the purpose of detach & disable was to transmit to other users that are not likely to be re-printing our sheets, but rather linking into their own models for developing their own scope. New views were fine and I've not heard anything from the other end that they've had weird visibility issues.) I will not bother with workset visibility in the future.
  5. #15
    Member FBlome's Avatar
    Menlo Park, California
    100
    11:49 AM
    Quote Originally Posted by sdbrownaia View Post
    ... For Enscape and Rendering entourage I like to use Design options with the primary option set to empty and the secondary on holds all the rendering assets, then only in render views do you set the design option to the secondary option. ....
    For rendering entourage, I create a later "Render" phase, and whatever needed views in that phase. It goes before my "Store stuff" phase....
  6. #16
    4,435
    07:49 PM
    4 Not allowed! Not allowed!
    Non-primary DO each & every time.
  7. #17
    Phoenix, AZ
    2,773
    11:49 AM
    Do you use DOs for all of these (legends, codes, units, etc.)?
  8. #18
    4,435
    07:49 PM
    Yup.
  9. #19
    Phoenix, AZ
    2,773
    11:49 AM
    I thought I heard something about Design Options and Linked Files for MEP being an issue... or am I remembering something else?
  1. Replies: 21
    Last Post: August 25th, 2017, 06:36 PM
  2. Slab Edge Visibility - shown and not shown
    By trevorpan in forum Structure - General Questions
    Last Post: January 6th, 2016, 03:02 PM
  3. remove time from date/time stamp in titleblock REVISITED
    By ledgewood33 in forum Architecture and General Revit Questions
    Last Post: July 22nd, 2015, 03:09 PM
  4. Ensuring compatibil​ity between versions?
    By doni49 in forum Third party Add-Ins, API and R&D
    Last Post: July 16th, 2014, 01:54 AM
  5. Get The "Project Information" Shown On The Sheets!How ?
    By Tinyman in forum Architecture - Family Creation
    Last Post: September 12th, 2011, 07:59 PM
