Thread: Asking Architects Linked View
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    330
    10:32 PM
    I'm posting this in the arch section because I want architect's opinions. Sometimes we'll run into issue with MEP that could be solved by using the linked view option in your templates. Is there a good way to ask architects for this and to provide them with the settings?
    I was thinking of having an empty project with one view template they can transfer over.
    Have you ever been asked this? Have you done it?
    This office is my first experience in a E only firm. My last firm it was much less of an issue because were working so much closer in multiple ways.
    11,261
    09:32 PM
    Quote Originally Posted by CRapai View Post
    So, generally when i get requests like this, its for an irrational (EDIT: And im not talking about you, im saying typically, thats why i get asked this) reason. So lets back up, for a minute:
    What SPECIFIC "issue" in MEP is solved ONLY by using BY Linked View, off of a specific view that would then need to be created in the Architectural Model?
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,578
    08:32 PM
    We generally create linked views, and MEP generally uses them. It graphically looks better, and should be easier for both parties if I adjust what I don't want to see in the background rather than asking them to turn off categories, add subcategories and custom filters.
    Since we have a link view template already I'd modify that if we worked together.
    December 20, 2010
    1,149
    10:32 PM
    2 Not allowed! Not allowed!
    We had an MEP firm request linked views with our room tags turned on. I told them this was a bad idea. We can certainly do that, but what happens when they need to move the tag cause its hiding an object they need to show. So generally speaking I'm not sure why MEP can't set up their own view templates to show the arch info they want to see. Don't get me wrong, I'm happy to set them up if there is a value to them but I'm not sure what settings I have differently then they do.
    April 30, 2015
    Michigan
    330
    10:32 PM
    The thing I was trying to solve yesterday was having sanitary pipe visible below the current level but not the walls. Sometimes this isn't as big of an issue but depending if designers want this working views and/or print views and how the walls are modeled it can be tricky. Maybe this is just because the architect modeled the walls up to the floor level rather than stopping at the slab. What I would really like is the ability to filter elements based on whether the reference level is below, above, or the current level.
    The designer just wanted it for a working view so we found a linked view that was relatively empty and set the view range to by linked view.
  1. Certain tags in a linked model show questions marks when VG set to "By Linked View"
    By cacbarbieri in forum Architecture and General Revit Questions
    Last Post: March 11th, 2019, 09:40 PM
  2. Electrical Fixtures from Linked Architects model
    Last Post: June 6th, 2016, 03:48 PM
  3. Object in linked file not visible in 3-d view - appears in hidden view as unhidden
    By theotheranony in forum Architecture and General Revit Questions
    Last Post: June 9th, 2014, 08:52 PM
  4. Cannot show Linked View in Linked Model
    By youseeitsme in forum Architecture and General Revit Questions
    Last Post: November 20th, 2012, 09:04 PM
  5. Architects file linked into Interiors File
    Last Post: July 2nd, 2012, 09:25 PM
