Thread: Printing to PDF issue on floor plans
    July 14, 2019
    4
    01:14 PM
    Hi All,
    Hoping you can help with a tricky issue of printing to PDF sheet views.
    The problem is that the Title, elevations, 3D views on a sheet views print perfectly but whet I do the floor plans it either cuts half of the sheet off or puts it at a different size in the bottom right corner. Interestingly it works perfect normally but not this time.
    Can anyone help?
    Thanks
    Hypa
Name:	revit sheet print issue.png
    1,691
    05:14 AM
    All I can think of is that there is something on the left side of that floorplan.
    Check your crop region and crop view.
    July 14, 2019
    4
    01:14 PM
    Thanks for the reply mate.
    After much hair pulling, it turned out to be a new North Point that we are using, it had an origin point way off to the left off the sheet.
    As soon as I modified the family, I knew it would work and it printed perfectly
    Ah the joys of Revit Modelling, still love it and man it can catch you out quickly!
    Thanks again
    Cheers
    Hypa
    1,691
    05:14 AM
    Tell me about it
    Nice that it turned out to be something simple in the end.
    Member Geert's Avatar
    February 8, 2011
    188
    05:14 AM
    Ran into the same problem with a PDF underlay on a sheet.
    When snap to PDF was on it would mess up printing. When snap was off it printed all right. PDF content can live outside the visible border it turned out.
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    912
    01:14 PM
    A good tip. Before i print i go to every sheet and do a ZA. If sheet is dead centre of display the all good. If not, it will indicate where a stray lurker is by biasing the sheet to the other direction in the display.
  1. Area Plans on Plans Other Than Floor Plans
    Last Post: April 16th, 2019, 01:56 PM
  2. Staircase treads on floor plans and ceiling plans.
    By BIM Warrior in forum Architecture and General Revit Questions
    Last Post: September 20th, 2018, 10:49 AM
  3. Using area plans instead of floor plans
    By Whatuser in forum Architecture and General Revit Questions
    Last Post: June 4th, 2018, 01:00 AM
  4. Creating HVAC Layouts use ceiling plans or Floor Plans
    Last Post: October 23rd, 2017, 09:58 PM
  5. Difference Between Floor Plans and Structural Plans
    Last Post: October 25th, 2016, 04:39 PM
