Thread: PDF File Size
    Member koolair's Avatar
    July 31, 2014
    273
    07:59 PM
    PDF File Size
    What are your pdf file sizes like?
    I print 36x54 sheets with title block (c/w logos), floor plan, rcp.
    I have arch, struc, mech eng (filter out all except p-fix).
    Tag all:
    engineer's pfix
    stuctural's columns
    arch's rooms and ceilings
    obviously all of my stuff too.
    Roof gravel/green roof hatching on
    drop panels on floor above (via rcp) are on and hatched (conc).
    floors are hidden.
    My pdf files range from 4 to 8 MB for 1:50 drawings.
    Admittedly there's a lot of graphics on the drawing but I felt it made the drawing more comprehensive especially on a live BIM360 design build project. More conversations and details get fleshed out on a drawing with lots of legible stuff on it.
    Engineer's 1:100 drawings are 400kb, however it requires a lot of jumping around from arch/struc/elec cross checking stuff.
    Tried looking for a pdf compressor but all that's available are online upload/download later web sites. Not interested.
    Any ideas?
    6,331
    07:59 PM
    Is that for individual pages or for the whole set?
    July 31, 2014
    273
    07:59 PM
    One sheet. =(
    Sent from my SM-N950U using Tapatalk
    November 4, 2012
    Budapest, Hungary
    126
    01:59 AM
    Most important: vector or raster pdf.
    Raster pdfs file size doesn't depend on the number of displayed elements, only on the resolution.
    Vector pdfs file size can grow huge if you display a lot of elements, or if you use heavy hatches. However as they are vectors, they don't have a resolution, you can zoom in indefinitely (or until the pdf viewer lets you zoom in) without losing a detail. Also view scale doesn't matter with vector printing, 1:50 and 1:100 should generate similar file size.
    Revit will show you a warning if you select vector, but it can only print in raster. The reasons for this are in the help: https://knowledge.autodesk.com/suppo...E0615-htm.html
    Which one is the better depends on the use case of the pdfs:
    - If you will just print them, display on a monitor doesn't matter, than check the resolution of the printer and print a raster pdf in that resolution.
    - If you want to view it on a screen, it's better to stay on vector. Try to repace your hatches to something not that heavy, a lot of hatches contain unnecessary lines. Also check if some families has a lot of lines which are hidden by lineweight.
  1. C4R and File size
    By AdamHamilton in forum Worksharing, Revit Server & C4R
    Last Post: September 1st, 2015, 09:15 PM
  2. File size
    By candystink in forum Architecture and General Revit Questions
    Last Post: September 12th, 2014, 08:43 PM
  3. File size managing/ sheets in different file
    By leetecture in forum Architecture and General Revit Questions
    Last Post: December 5th, 2012, 09:48 PM
  4. File size
    By Walica in forum Architecture and General Revit Questions
    Last Post: October 31st, 2012, 04:16 PM
  5. Dispelling the misconception about File Size and File Performance
    By Twiceroadsfool in forum Architecture and General Revit Questions
    Last Post: September 24th, 2012, 09:34 PM
