Thread: Tilte Drawing
    February 13, 2020
    Georgia
    08:51 PM
    Tilte Drawing
    Hello everybody,
    I am new to Revit and taking classes at a Community College, while I was doing my drawing I rotated the canvas and when I was done i set it back but incorrectly, now I can't set it back to have my lines straight in the entire drawing. I am probably off by a degree or something but every time I try to make it straight it does not work. I thought it was the screen until I open another lesson with the similar drawing and the lines are straight on that one, I have try to align with coordinates and every line I draw is not straight. Any help would be greatly appreciated.
    I asked the teacher and he can't figure it out either.
    Thank you.
    3,194
    07:51 PM
    Revit doesn't like rotating by tiny increments.
    Try rotating it by something like 20 or 30 degrees, and then rotate back using the snaps.
    Or if you can get a model line or a model at exactly 0 degrees, rotate your model off again, and then use Align to get it back
    February 13, 2020
    Georgia
    08:51 PM
    Thank you Dave,
    The small increment was not intentional, it probably happen when I was setting the drawing back to zero.
    "Or if you can get a model line or a model at exactly 0 degrees, rotate your model off again, and then use Align to get it back" I have tried but every time I draw a new line is given in the same minute angle. We try rotating the drawing by a different degrees and set it back to 0 and same result, even the teacher try. The site plan is correct align to north 0 and looks correct the lines are straight. The shifting lines is on the actual floors.
    I also try to align to straight line using the coordinates, but since that the line is in the same drawing the result is the same.
    I also check the survey point and north orientation and they are both at 0.
    May 20, 2011
    Chicago, IL
    798
    08:51 PM
    2 Not allowed! Not allowed!
    Creating a new floor plan should fix the problem.
    view -> plan views -> floor plan -> uncheck do not duplicate… -> level 2
    February 13, 2020
    Georgia
    08:51 PM
    PijPiwo,
    It worked!!! Thank you. I just got home from work and it was a long day, but you just made my day.
  1. drawing iso
    By philsogood in forum MEP - General
    Last Post: November 7th, 2019, 08:12 AM
  2. Drawing on walls
    Last Post: June 4th, 2014, 02:28 PM
  3. drawing adjutment
    By samifox in forum Structure - General Questions
    Last Post: June 26th, 2012, 02:12 PM
  4. Comments on drawing
    By Pere in forum Architecture and General Revit Questions
    Last Post: June 6th, 2012, 12:36 PM
  5. drawing scale
    By joss in forum Architecture and General Revit Questions
    Last Post: April 2nd, 2012, 06:28 PM
