Results 1 to 9 of 9
Thread: Wall Display different in 2 files
    Member Damo's Avatar
    March 2, 2011
    London, UK
    143
    06:50 PM
    I have a wall in a project that displays like this on plan:
    But when I copied it into a template file it's showing like this:
    I'm looking for the cut patterns and colours to display as the Project version.
    I've checked the VG in the Template file and there are no overrides nor filters. Phases are the same too.
    The desired Cut Pattern properties of each of the elements show correctly in the template file.
    Template File - Brick Properties:
    Template File - Insulation Properties:
    Template File - Block Properties:
    But this is not what I'm getting.
    What am I missing?
    BTW, whilst posting this, I've noticed that the thumbnail on the browser properties in the Project doesn't show what is displayed but shows what I'm seeing in the template file:
    Thanks
    Last edited by Damo; February 14th, 2020 at 09:51 AM. Reason: Corrupt images replaced
    1,509
    07:50 PM
    OK not sure what was happening to the images in your post, but they ended up as a lot of gibberish text.
    I have removed them, so please try and add them again if you like.
    March 2, 2011
    London, UK
    143
    06:50 PM
Name:	2 Wall, as should be.jpg
Name:	2 Wall Plan.jpg
    The desired Cut Pattern properties of each of the elements show correctly in the Edit Type -> Type Properties -> Edit -> Materials Browser in the template file.
Name:	2 Brick Prop.jpg
Name:	2 Insulation Prop.jpg
Name:	2 Block Prop.jpg
    What am I missing?
Name:	2 Wall Properties.jpg
    Thanks
    2,714
    04:50 AM
    Phase overrides?
    March 2, 2011
    London, UK
    143
    06:50 PM
    Phase overrides?
    Nope. Both Phase & Phase Filters are the same. I can see no Phase Graphic Overrides that would be doing this.
    March 2, 2011
    London, UK
    143
    06:50 PM
    OK, Got it.
    Visual Style Hidden verses Visual Style Shaded were different in the Project and my Template.
    Learned something which should have been very basic.
    March 2, 2011
    London, UK
    143
    06:50 PM
    This is driving me nuts.
    I can just about get the colours looking right but when I adjust a colour, eg: say a Cut Pattern background colour RGB to a lighter shade, it disappears. Seem that I can only choose a bold colour, not a subtle pastel colour.
    Changes the brick from RGB 255 128 128 (shows OK) to RGB 255 183 183, and the colour goes completely.
    Same thing happens if I change the Shading colour.
    Another example:
  8.    #8
    6,329
    01:50 PM
    Video card driver needs updating maybe?
    Could you post sample files with that wall in it?
  9.    #9
    March 2, 2011
    London, UK
    143
    06:50 PM
    Hi Chad,
    Attached my file.
    BUT! When I brought this into a plain OOTB Revit template it is displaying fine when I alternate between Hidden Line & Shaded.
    So, where should I go looking for differences in how the display is being, well, displayed?
    Thanks
  1. Wall common edg display
    Last Post: October 31st, 2017, 08:45 PM
  2. Wall display error. Please help!!!
    By asnl1234 in forum Architecture and General Revit Questions
    Last Post: December 23rd, 2013, 12:09 AM
  3. Linked CAD files do not display, don't show up in "Manage Links" menu
    By truthjusticeUSAway in forum MEP - General
    Last Post: October 13th, 2013, 12:25 AM
  4. Wall Tags for wall panels - Display in plan and elevation
    By JasonWallis in forum Architecture and General Revit Questions
    Last Post: January 30th, 2012, 07:45 PM
  5. Wall types will not display solid fill, strange wall type, and more
    By tweg in forum Architecture and General Revit Questions
    Last Post: December 1st, 2011, 07:56 PM
