Results 1 to 6 of 6
Thread: Schedule Seating Calculated as an Integer
    Member Chadwick17's Avatar
    Fort Collins, CO
    323
    03:51 PM
    I feel like this is possible, but I must be doing something wrong. Is there a way to schedule a value that is calculated as an integer? I'm trying to calculate seating totals of church pews based on a given width per person. There's a parameter in the pew family that divides the length of the pew by the set width for each person. Then there is another parameter that takes that decimal number and rounds it down to give the total seats for that pew length.
    I'd like to get all of these different pew sizes into a schedule that will then run a total of seats available. Ideally I'd like to show the different totals for a few different widths without having to count a hundred families three different times.
    Any help would be appreciated.
    1,534
    11:51 PM
    Yep easy, make the seating parameter a shared one and you can schedule it
    Fort Collins, CO
    323
    03:51 PM
    Thank you. I really need to brush up on my Revit skills apparently.
    1,534
    11:51 PM
    you are very welcome !
    6,352
    05:51 PM
    Quote Originally Posted by Chadwick17 View Post
    We all do. Just to different levels
    July 7, 2017
    Hernando, MS
    581
    04:51 PM
    shoot, I'm a nearly 16-year Revit veteran and I still learn new stuff almost every day!
  1. Use schedule totals in calculated values
    By Wes Macaulay in forum Architecture and General Revit Questions
    Last Post: November 15th, 2019, 04:53 AM
  2. Area Schedule - Calculated Value Not Showing, sometimes
    By mdsharp5 in forum Architecture and General Revit Questions
    Last Post: August 1st, 2019, 10:54 PM
  3. Dynamo Get Calculated Value from a schedule
    By rdon in forum Dynamo BIM
    Last Post: December 19th, 2015, 03:03 PM
  4. embedded schedule calculated value
    By jmuratore in forum Architecture and General Revit Questions
    Last Post: July 29th, 2015, 07:58 PM
  5. Use Calculated Area in Material Schedule
    By Herra in forum Architecture and General Revit Questions
    Last Post: July 16th, 2012, 04:16 PM
