Thread: Revit- Face base family Annotation
    April 25, 2011
    25
    10:46 AM
    I have created a fire alarm panel family(Face base) with nested annotation.
    I want to move this annotation by using parameters. I can move annotation along with the base(Wall).
    I am not able to move the annotation vertically from the base.
    Is there any solution available to do the same?
    Thanks
Name:	move along base.jpg
ID:	38340   Click image for larger version.
Name:	Move Vertically.jpg
    February 19, 2017
    19
    08:16 AM
    Hello, the reason is, face based families constrain themselves to reference planes which they defined to. You need to assign a parameter from reference in family editor to move it vertically. Then you can enter a distance and move it by that way.
    June 21, 2012
    Tours, France
    1,116
    07:16 AM
    2 Not allowed! Not allowed!
    Quote Originally Posted by swapr78 View Post
    Thanks
    Hi swarp78!!,
    Totally doable , just follow this steps:
    1. Create a reference plane "Strong reference" away from the solid object (the face object into the family environment) and name it anno_ref_plane (or whatever you want)!
    2. Create a dimension and convert it into a parameter called anno_placement (or as you want), and be sure that is an instance parameter!
    3. Constrain the annotation to the new reference plane!
    Once you'll do this you may be able to move you annotation symbol as desired!!
    Enjoy
    let me know if you succeed! best regards
    3,172
    10:16 PM
    Movement parallel to the wall is easier than away from the wall. You can use parameters in the host family for parallel but you need to define the origin for movement off to one side of the cabinet so it can be moved left or right of center. If defined based on the center you'll only be able to move it to one side, not the other.
    Moving it away from the wall is more difficult because the symbol won't move away from the wall in the host. The movement needs to be defined in the symbol family and then the parameter used to shift it away from the origin in the symbol family needs to be mapped to a parameter in the host family.
    Parallel to Wall - distance is entered in real world units (e.g., 1'-2")
    Away from Wall - distance is entered in "paper space" units (e.g., 1/8")
  1. Nesting Generic Annotation Family into Face Based Light Fixture Family
    By dmudd in forum Architecture - Family Creation
    Last Post: November 5th, 2019, 10:44 PM
  2. Changing Face Based to Unhosted Family - Delete the Face Host?
    By blusurfer in forum Architecture - Family Creation
    Last Post: December 13th, 2017, 06:32 PM
    Last Post: October 15th, 2013, 01:15 AM
  4. Face based family annotation symbol
    By domsib in forum MEP - Family Creation
    Last Post: August 28th, 2013, 04:44 PM
  5. generic annotation in face based families
    By ekkonap in forum Tutorials, Tips & Tricks
    Last Post: November 15th, 2012, 02:57 PM
