Results 1 to 9 of 9
Thread: Lines trimming in nested families
    February 22, 2013
    375
    03:08 AM
    This is MEP related, but I thought that posting it here would attract more eyeballs...
    So I recently discovered the trick of placing nested face-hosted families in my mechanical equipment families. It really simplifies the parent family by moving a lot of the constraints and ref planes into the nested families. I've started updating our standard families to make use of these, but I've noticed a graphical issue: where the face-hosted nested family touches the geometry of the parent family, Revit is trimming the lines in Hidden Line mode.
    For instance, I just created a spiffy, fully parametric family for a condenser fan. I nested it into a face-hosted family, and then nested that family into my split system condensing unit family. As you can see in the image below, the lines of my nested condenser fan family are being trimmed.
Name:	Nested Families.jpg
    Is there some way to stop Revit from trimming these lines while keeping the View in Hidden Line mode?
    10,875
    02:08 AM
    Ehhhh, something else is going on there. I nest stuff in other stuff all the time, including Face Based, and it doesnt take my lines out, like that.
    February 22, 2013
    375
    03:08 AM
    I did just discover that if I change the Condenser Fan to Generic Model family category (#1 in my image), but keep the face-hosted family (#2) as a Mechanical Equipment, this line trimming behavior doesn't happen. But, because my Views are using the hard-coded "Mechanical" Discipline setting, Generic Models are set to halftone, which isn't ideal. I'm not sure how to override that Discipline setting, though.
    Apparently the Generic Model family category is special in this regard.
    3,147
    12:08 AM
    It's probably Cut vs Not Cut... Mechanical has no Cut settings while GM does.
    February 22, 2013
    375
    03:08 AM
    I just tried making sure that "Cut with Voids When Loaded" was unchecked for all families.... no luck. The only family category that seems to prevent this triming behavior is Generic Model.
    I have found that if I set the view Discipline to "Coordination" instead of "Mechanical", the GM category is no longer halftoned. I suppose I could make this change globally, but this would probably lead to other issues.
    September 19, 2017
    Seattle, WA
    82
    12:08 AM
    2 Not allowed! Not allowed!
    I've encountered this. It's a function of Mechanical Settings -> Hidden Line -> Outside Gap. Change that to 0" and it should go away. At least that's what has worked for me in the past.
    EDIT: You can also undo the halftone that's applied in Mechanical views by going to Additional Settings -> Halftone/Underlay -> Underlay -> Apply Halftone (uncheck). Of course, then you have to re-halftone everything that you do want halftoned, so YMMV.
    February 22, 2013
    375
    03:08 AM
    Quote Originally Posted by Robert Roffe View Post
    Wait, so I can uncheck that "Apply Halftone" box and still have halftones applied by V/G settings? That's news to me, I always thought this was a global shutoff of ALL halftoning in the entire model, which seemed stupid to me so I always left that box checked.
    10,875
    02:08 AM
    I didnt even know that was a thing (Outside Gap). So, thanks!
    February 22, 2013
    375
    03:08 AM
    Proper looking MEP plans need both gaps, though. It looks weird when two ducts pass each other and the outside gap is set to 0”.
    But turning off “Apply Halftone” did the trick! In summary (in case anyone reads this years from now), it looks like nested/face hosted MEP families need to be on the Generic Models family category if you want to avoid this line trimming inside your families.
    Last Post: September 5th, 2013, 01:45 AM
  2. How do Lines Subcategories carry over when nested?
    Last Post: November 28th, 2012, 03:27 PM
  3. Nested families updaten
    By Robin Deurloo in forum Nederlands forum
    Last Post: August 29th, 2011, 09:44 AM
  4. Nested family and Ref Lines
    By Gordon Price in forum Architecture - Family Creation
    Last Post: February 20th, 2011, 09:17 PM
  5. Nested Objects in Families
    By JCM in forum Architecture - Family Creation
    Last Post: February 11th, 2011, 11:12 PM
