Results 1 to 10 of 15
Thread: Sketcy Lines - wierd printing
    May 14, 2012
    462
    12:18 AM
    We had an interesting phenomenon happen yesterday using sketchy lines: the model part of the middle third of the building would not plot to our plotter from one computer. I even had the user create a PDF first (which looked fine), then send it to the plotter and the plotter still left out the middle section, but just the model, not the annotations:
Name:	IREA WP Plot 200224.png
ID:	38429 vs Click image for larger version.
Name:	IREA WP PDF 200224.png
    I had him test it again after restarting the computer with the same result. As an additional test, I plotted the PDF as well as directly from Revit from my computer and it printed just fine. For now, we're abandoning the sketchy lines, but I still want to solve this mystery.
    Has anyone else experienced anything similar?
    January 15, 2020
    The Netherlands
    87
    08:18 AM
    This doesn't have to be Revit related.
    I the past i have had a lot of problems with plotters, half off the page, parts not printing (like urs) ect...
    I have worked at 3 companys and they all have the same issue with plotters, they seemed to vary on each pc, some work fine, and some dont work at all.
    Plotters are just wierd
    1,544
    08:18 AM
    I believe this could be a printer setting. There usually is a setting that determine if a job goes to the plotter only if the spooling process is all done or in batches. Could be that that one pc sends the entire thing to the plotter at once and the plotter can't handle that.
    Forgot what the setting is called and where to find it, will check that tomorrow when I wake up again (a bit late here now).
    1,544
    08:18 AM
    These are the settings I'm talking about:
Name:	printer settings.JPG
    May 14, 2012
    462
    12:18 AM
    Attachment 38440
    Hmm ... it says "invalid attachment" when I click the link.
    1,544
    08:18 AM
    weird, updated the post and it should be OK now
    May 14, 2012
    462
    12:18 AM
    Yeah, that happened to me when initially creating this thread ... actually, I had started, then cancelled, so when I tried again and clicked "load autosaved content", the pictures didn't load with the text. I had to re-upload the images.
    I had the user compare my settings (that work) to his and they match:
Name:	Plotter properties - Advanced.jpg
    1,544
    08:18 AM
    Then I'm out of ideas, sorry.
    6,361
    02:18 AM
    Are the rest of the plotter settings the same? Speed, DPI, Line Drawing vs Image, etc?
ID:	38457   Click image for larger version.
    May 14, 2012
    462
    12:18 AM
    Where do I look for these settings? (I feel like I saw another "Advanced" button yesterday, but now I can't find it.)
  1. Printing Thin Lines to PDF
    By Noam_r in forum Architecture and General Revit Questions
    Last Post: June 28th, 2018, 09:08 PM
  2. Lines Printing out to Thick
    Last Post: July 1st, 2015, 01:39 PM
  3. Fire lines printing irregularly
    By mhug9 in forum Architecture and General Revit Questions
    Last Post: June 18th, 2014, 09:17 AM
  4. Solid element lines printing as hidden lines???
    By imcarter33 in forum Structure - General Questions
    Last Post: June 13th, 2014, 07:48 PM
  5. Printing grey vs thin lines
    Last Post: March 30th, 2011, 03:38 AM
