Results 1 to 9 of 9
Thread: How can a parameter disappear?
    3,359
    08:29 PM
    I'm working on a Plumbing Fixture that has a nested family.
    It has a Shared Parameter (Family Type) the calls out the faucet handle.
    When I look at one of my Family Types, I see the Family Type parameter
    But when I try switching to a different Type, that parameter doesn't even show up in the dialog, and I get an error
    How can a parameter disappear from Type to Type?
ID:	38512   Click image for larger version.
ID:	38513   Click image for larger version.
    Last edited by DaveP; March 9th, 2020 at 06:51 PM. Reason: Sorry, apparently you can't delete an attachment
    Wellington, New Zealand
    747
    01:29 PM
    Hmm - not sure But Id just delete the offending type and recreate?
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    150
    03:29 AM
    If you share the family, i can try if i get the same thing.
    Seems impossible that a family parameter does not show up on different types? maybe a problem with a type catalog?
    Have you tried making it a type parameter, and see what happens next? Make it shared, see if that makes a difference?
    3,359
    08:29 PM
    It is a Shared Parameter. No Type Catalog.
    The thing is, I've got a bunch of parameters in each Type, and I'd rather not reset all of them.
    I was kind of shocked when I saw the parameter just disappear from the dialog.
    I agree. It seems impossible
    I tried saving and reloading with an Audit, and the same thing happens.
    11,165
    08:29 PM
    2 Not allowed! Not allowed!
    If someone deleted a Faucet Family that is the default option for a Family Type, with that Shared Parameter: Yes, the entire parameter gets deleted. Its terrible behavior, and its been that way for years.
    EDIT: By the way, in case i wasnt clear: This is a known issue, and its easily reproducible.
    1. Take any Family that uses a Shared Family Type Parameter, that has a default value.
    2. Find the family in the project browser, that is the Family and Type thats in the default value.
    3. Delete that family from the PB.
    4. After youve clicked *DELETE* in the warning, go back to the original Family (the parent family with the parameter).
    5. For JUST the types that had that default value set... That parameter is now gone.
    And yes... the instances in your project are hella broken, now.
    6,387
    09:29 PM
    Does a reload not fix it?
    11,165
    08:29 PM
    I havent had good luck, personally, as (in my experience, anyway) you need to Reload AND Override Parameters, to fix it. That might be wrong though. Its not an issue i face often, as i know how to avoid it. But if you have to reload and Override, for me that effectively destroys everything anyway.
    3,359
    08:29 PM
    Haven't tried this yet (I ended up manually recreating my Types), but I wonder if you could Export a Type Catalog, delete the bad Types, and the Import the Catalog to recreate everything?
    Might require manually editing the Type Catalog if the bad Types don't export properly.
    11,165
    08:29 PM
    I dont believe thats going to help with instance parameters resetting, at all.
  1. Walls Disappear in PDF
    By squiz in forum Architecture and General Revit Questions
    Last Post: November 20th, 2018, 10:40 AM
  2. Some columns disappear in rendering
    By ellebrant in forum Rendering and Gallery
    Last Post: May 16th, 2017, 08:36 PM
  3. Dimensions disappear
    By archgirl86 in forum Architecture and General Revit Questions
    Last Post: June 3rd, 2013, 08:18 PM
  4. lights disappear?
    Last Post: November 4th, 2012, 08:44 PM
  5. Portions of UI disappear
    By Steven Thedens in forum Architecture and General Revit Questions
    Last Post: May 2nd, 2012, 10:32 PM
