Results 1 to 10 of 11
Thread: Is there a way to run a script or automation what will fill in all "MARK" fields
    December 27, 2011
    164
    09:59 PM
    Is there a way to run a script or automation what will fill in all "MARK" fields for all item in the project?
    notice: i dont know how to use dynamo.
    February 22, 2013
    378
    03:59 PM
    Notice: It’s time to learn Dynamo.
    Dynamo IS the scripting/automation tool that comes with Revit. It’s so easy to use that it’s actually fun. Just start playing with it. You can probably do this with a very simple Dynamo graph.
    1,543
    09:59 PM
    I made a dynamo script a while back to change all the 'marks' to get rid of the duplicate mark errors. We are not going to use thise marks, but the errors bugged me. So yes very possible.
    December 27, 2011
    164
    09:59 PM
    Can you give me a clue where to start? i'm opening it and get confuised
    November 18, 2016
    160
    07:59 PM
    Quote Originally Posted by danezeq View Post
    dynamo can be confusing if your brain doesnt work in the way dynamo does. in reality it's very logical and you need to plan out what you want to do step by step. the little boxes are called nodes and you lace them together to form a chain reaction.
    go to the dynamo site, there's a great forum on there and you may even find your problem has already been resolved and you can copy the script.
    December 27, 2011
    164
    09:59 PM
    Thank you so much.
    i'll go ahead and do that
    1,543
    09:59 PM
    There was a AU class by Marcello Sgambelluri that was my aha! moment. Not at home right now, bit I can look it up for you later today.
  8.    #8
    February 22, 2013
    378
    03:59 PM
    Read the Dynamo Primer, but skip the parts on geometry. Focus on the parts that deal with list processing.
    https://primer.dynamobim.org/
    Or you can do what I did and just play around with it. Drop the nodes "Catagories" and "Select all elements in Categories", connect them and watch what happens. Then start playing with it.
  9.    #9
    Member duende123's Avatar
    November 20, 2015
    198
    03:59 PM
    make a schedule
    disable "itemize every instance" in sorting / grouping
    fill in the parameter value
  10.    #10
    May 14, 2012
    462
    01:59 PM
    I agree ... I finally decided to invest a few hours this week into going through an initial tutorial set (Dynamo 2.x Essentials on Lynda.com/LinkedIn Learning). I still have a ways to go before it's instinctual, but it's a start.
  1. Get "type" parameter of instance in Python Script
    By engineer in forum Dynamo BIM
    Last Post: March 20th, 2019, 11:43 AM
  2. Replies: 3
    Last Post: January 23rd, 2019, 06:52 AM
  3. Using "Type Mark" or "Mark" / best method
    By secondguesser in forum Structure - General Questions
    Last Post: December 8th, 2016, 01:24 AM
  4. Beam Tags & Labels, not switching to "Type Mark"
    By Dseven24 in forum Structure - General Questions
    Last Post: October 16th, 2013, 11:07 PM
  5. "I've lost Mark" user error has me stumped (RAC2011)
    Last Post: June 29th, 2011, 01:43 PM
