Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: Print Sheets in Order (Workaround Tip)
    March 13, 2020
    5
    02:17 PM
    -1 Not allowed! Not allowed!
    I thought I'd share this tip as a possible workaround for printing sheets in the order you want.
    Example - Sheet names are T100, A100, A101, S100, S101, E100, E101
    Add a "sort" number in front of the sheet name: 1-T100, 5-A100, 5-A101, 6-S100, 6-S101, 8-E100, 8-E101
    Now your sheets are in proper print order, but you don't want to see the sort number on your sheets.
    Mask the Sort Number: Use text with mask on and change color of text to 254,254,254 (in text style properties). This text is your mask. I used a period and added spaces as needed for the mask.
    Group the masking text, then paste (Modify/Paste/Align to selected views) the group to all sheets over the sort number.
    For the Drawing Index, do the same. You may use Array to array the text over the sort numbers, or use a single text with spaces as needed.Click image for larger version.
ID:	38540Click image for larger version.
    1,543
    09:17 PM
    3 Not allowed! Not allowed!
    To be honest if you care about the order of your sheets in your project browser that much you need to rethink the numbering of your sheets and not use these kinds of weird 'work arounds' to hack the order.
    Junior Member cwasher's Avatar
    Rogers, AR
    31
    02:17 PM
    If you have Bluebeam, the easiest workflow I have found is to print your entire set as individual PDFs to a folder. Once all the PDF files are dumped into that folder, create discipline sub-folders prefixed with the sort integer. For example: 01-General, 02-Structural, 03-Arch, 04-Mechanical, etc... Drag the PDFs into their proper folder, sprinkle in the consultant PDFS.
    Once sorted, just select all the folders, Right-Click, and "Combine in Bluebeam"... Bluebeam will staple them together ordering them by the sub folder and then by the sheet number. The whole process may take a few minutes max. At the end, not only will you have a organized grouping of all the individual PDFs for use, but also a combined set.
    March 13, 2020
    5
    02:17 PM
    This isn't about the project browser. This is about sending sheets to a printer in a specific order (to avoid the step of collating or reassembling PDFs). Revit only sends prints in the Sheet Number parameter. There is no other way (batch plot is garbage).
    Quote Originally Posted by cwasher View Post
    In my method, I send a print to a virtual PDF printer (Adobe Distiller) and it's a complete PDF. No need to organize or rename anything. The only drawback with my method is I need to be sure the masks are covering the sort number.
    10,889
    02:17 PM
    Good grief.
    Or just leave the PDFs as separate files, the way they should be, anyway.
    Seriously, if I saw someone masking parameters labels on a sheet, I'd flip out all over them. That's just awful. And unnecessary.
    No offense meant, of course.
    1,543
    09:17 PM
    Quote Originally Posted by tplarkin7 View Post
    OK I had misunderstood you, but my comment still stands. If the order of your PDF is that important, you need to rethink the numbering of your sheets and not hack something to get it to work. But I also agree with Aaron, as far as I know I have never made a combined PDF other then a booklet for details and I'm sure that even if I did I have my sheets numbered in a way it will work.
    Member Marcel Jansen's Avatar
    December 25, 2011
    The Netherlands
    245
    07:17 PM
    Not for ordering your PDF, but if you print all of the sheets to 1 PDF you can make your details clickable in your sections and floorplans.
  8.    #8
    2,765
    05:17 AM
    Quote Originally Posted by Marcel Jansen View Post
    It works for drilling down through view references but sadly, you can't go back up.
  9.    #9
    Long Beach, CA
    206
    12:17 PM
    What do you do about all your section, elevation and callout references that now report that prefix for all your sheet numbers? Are you masking those too? I'd lose it if i caught a team member putting masking regions all over our drawings. Or are you adding a parameter in addition to the sheet number? Either way, one extra thing for people to manage, and one extra thing for them to screw up.
    Just get Bluebeam and use the plugin to sort your prints, or post-process on the Bluebeam side. Not that difficult.
  10.    #10
    March 13, 2020
    5
    02:17 PM
    Quote Originally Posted by kingjosiah View Post
    All references are also masked (edit the family and use text or labels to mask).
    Masking sounds like a pain, but you only need to do it once. The only babysitting is with the Drawing Index.
    The whole point of this to avoid assembly when printing, and it works. You print a complete, and ordered set in one shot (the way it's supposed to be).
  1. Print Only Sheets in Bulletin
    By Juniper01 in forum Architecture and General Revit Questions
    Last Post: September 19th, 2016, 09:11 AM
  2. Print order placing halftone over black lines
    By DavidLarson in forum Architecture and General Revit Questions
    Last Post: March 17th, 2016, 06:46 AM
  3. Printing sheets in order to PDF
    By rosskirby in forum Tutorials, Tips & Tricks
    Last Post: July 18th, 2015, 07:58 PM
  4. Print to PDF, Printing 50 Sheets? You Get 50 Sets of the 50 Sheets
    By chompi0n in forum Architecture and General Revit Questions
    Last Post: November 27th, 2014, 01:34 AM
  5. Sheets won't sort in order
    By mmarshall in forum Architecture and General Revit Questions
    Last Post: April 25th, 2014, 10:56 PM
