Thread: Wall footing issues
    May 27, 2013
    4
    12:04 AM
    Wall footing issues
    In Revit 2020, offset wall footings: I can't put in an eccentricity before placing the footing; I need to place it, then select it and change the eccentricity.
    When I have 2 intersecting footings that are eccentric, they still extend beyond the corner (as if perp footing is centered on wall).
    Also, how do I change footing widths along length of same wall? I can lengthen footings beyond walls but can't shorten them less then actual length of wall.
    December 11, 2010
    Astana
    228
    01:04 PM
    Quote Originally Posted by MnSc View Post
    To create a foundation with an eccentricity, use the retaining type (Type > Structural Usage = Retaining).
    Check the Default End Extention Lenght type parameter.
    Use an in-place void or a face based void family.
    Member Modderhoop's Avatar
    January 15, 2020
    The Netherlands
    132
    09:04 AM
    Are you using the Wall Foundation tool?
    When using this tool i can easely drag the ends of the beams.
    2,791
    05:04 PM
    I'd rather use disconnected standalone footings, slabs or even structural framing(!) before i did that.
    But yeah, wall footings can be a PITA.
    January 15, 2020
    The Netherlands
    132
    09:04 AM
    I tend to use beams for more detailed foundations.
    When its just a school project or something small i use the wall foundation because its easier to use and faster.
  1. Revit OpEd: Eccentricity of Wall Footing
    Last Post: June 18th, 2019, 11:45 PM
  2. Thickened Slab Edge / Wall Footing
    By sdbrownaia in forum Structure - General Questions
    Last Post: October 30th, 2015, 02:14 PM
  3. Stepped footing not joining with Wall footing
    By AHutchinson in forum Structure - Family Creation
    Last Post: February 14th, 2012, 06:52 PM
  4. Precast Wall / Footing elevation
    By Procadd in forum Structure - General Questions
    Last Post: February 9th, 2012, 11:18 PM
  5. Exsting Wall Footing
    By cdepriest6009 in forum Structure - General Questions
    Last Post: February 1st, 2012, 08:28 PM
