Hi All
New in Revit and this forum.
I opened revit architecture and selected wall. and in the botton wall properties, I would like to bring inch measurement list over there. But it showing some different measurement list (as an attachment). I tried to change unit measurement from Manage>Project Unit. But this change only drawing.
How can I bring default properties there ? Please have a look an attachment. Any suggestion would be very helpful.
Thanks
Delprimo
Those are the names of the wall in your project and won't change no matter what type of units you use. I think there are default templates for both metric and imperial, so if you need inches you need to use the imperial template and you will have walls (and other stuff) that are named with imperial sizes that are default in that template.
