Thread: calculeted field in schedule to room tag
    August 3, 2017
    33
    08:40 PM
    so i created a schedule with cooling loads according to the area. then i made a room tag, tried to add a shared parameter, tried also without, but cant get the cooling load to show in the room tag. any help is appriciated
    Last edited by ChrisDarmanin; March 29th, 2020 at 05:44 AM. Reason: Can't correct spelling mistake in title, sorry
    August 3, 2017
    33
    08:40 PM
    So I wrecked my mind trying to find out how to do it and I think I learned what I wrote in the sketch below. It's it correct? Does it make sense?
    Sent from my Nokia 7 plus using Tapatalk
    Forum Addict jmk's Avatar
    December 31, 2012
    NM, USA
    1,556
    12:40 PM
    That looks accurate - the calculation has to be done separately in the tag and in the schedule.
    August 3, 2017
    33
    08:40 PM
    Thanks, this helped me understand revit better
    December 11, 2010
    Astana
    227
    12:40 AM
    Use Spaces with build-in cooling load parameters. You can synchronize the number and name of rooms and spaces.
    August 3, 2017
    33
    08:40 PM
    I know, I must learn it. It's not just drawing, it's bim
    February 22, 2013
    384
    02:40 PM
    Dynamo can be used to move data around your model and create connections that don't normally exist. I use it to move data back and forth between my Spaces, HVAC zones, and VAV boxes.
    Just don't go down the rabbit hole and make your Dynamo graph too complicated. Pick one or two specific things you want it to do and focus on them. Dynamo is easy get started with and, for me at least, this lead me to create monstrously complicated graphs that were hard to troubleshoot and VERY hard to explain to other users.
    August 3, 2017
    33
    08:40 PM
    thanks! we have a guy at the office who does dynamo but first i must learn revit. it can save a lot of time!!
  1. How to Color Schedule field - if field contains ...
    By tiangtiang in forum Architecture and General Revit Questions
    Last Post: October 3rd, 2018, 08:24 AM
  2. Schedule Field
    By Andythebear in forum Architecture and General Revit Questions
    Last Post: February 15th, 2017, 10:21 AM
  3. Room aware family - no "room: area" field available in schedule?
    By Paliskoo in forum Architecture and General Revit Questions
    Last Post: January 12th, 2016, 05:32 PM
  4. To Room Field is Completely Blank in Door Schedule
    By blusurfer in forum Architecture and General Revit Questions
    Last Post: September 17th, 2015, 01:47 AM
  5. Doors to/from room field not populating
    By Alex Page in forum Architecture and General Revit Questions
    Last Post: June 4th, 2012, 03:40 AM
