Results 1 to 9 of 9
Thread: Directory/Graph Naming Standards
    January 19, 2012
    347
    11:58 AM
    Wanted to get feedback of some of the best practices out there. From what I'm currently contemplating is the following...
    My typical graph naming is by (Process Category_Descriptor 1-& or 2_Dynamo Version).dyn
    sample:Export_Doors-Instance Parameters_v2.3.dyn
    Folder Structure is ["(Alphnumeric)_Process Category" -> "Revit Category" -> "Version"]
    December 11, 2010
    Astana
    228
    10:58 PM
    I found that instead of the Dynamo version it’s more convenient to specify the Revit version.
    So far I use this scheme: [DisciplineCode]-[Description]-[Author]-[RevitYearXX]
    Folder Structure: RevitYear \ Dynamo \ Discipline \ *.dyn
    6,389
    12:58 PM
    Mine are a mess, but I try to organize them something along these lines:
    What does it work on -- What is the general function -- What is it doing -- additional descriptive
    Manage-SubCategory-HideClearances
    Manage-CreateWorksets
    Sheets-CreateFromLevel
    Views-SetCropBoundaryLineweight
    Views-Delete-EmptyElevationMarkers
    It works to a point, but definitely needs some adjustments. Part of the struggle I have with naming them is that I'm not in Dynamo a lot, so how I think about naming them changes depending on the day... I really need to setup some sub-folders. I think that would help a bit.
    Member johnp's Avatar
    March 24, 2015
    180
    09:58 AM
    Regarding naming and sharing graphs, Orkestra is looking pretty darn promising. You are able to add meta data to the graphs to describe what they do and all that.. Video: http://a360.co/3blcwDp About: https://www.orkestra.online/
    Member kraftwerk's Avatar
    November 1, 2012
    St. Louis, MO
    72
    11:58 AM
    Quote Originally Posted by johnp View Post
    datashapes? looks interesting
    6,389
    12:58 PM
    Just got off of a call with Mostafa about Orkestra. It is looking pretty sweet!
    March 24, 2015
    180
    09:58 AM
    Awesome man!
    Member CRapai's Avatar
    April 30, 2015
    Michigan
    328
    12:58 PM
    Orkestra, hmmm... no inputs. Can data-shapes handle all the typical inputs? Is there anything missing? I looking into Dyno for a similar function a while ago but never moved forward on it.
    March 24, 2015
    180
    09:58 AM
    From what I hear, it has a tight integration with Data-Shapes for UI and inputs.
  1. Detailing to bs standards or sans standards using revit
    By eleanor in forum Structure - General Questions
    Last Post: December 24th, 2015, 01:18 PM
  2. CAD Layer Naming Standards
    By NavisBro in forum Coordination Tools
    Last Post: May 1st, 2015, 03:47 PM
  3. Lost my left side project directory
    By ChrisInTexas in forum MEP - General
    Last Post: February 11th, 2014, 09:41 PM
    Last Post: November 4th, 2011, 07:43 AM
