Results 1 to 10 of 10
Thread: Railing with Arched Pickets
    6,389
    07:33 AM
    I need to create a railing with pickets that arch from baluster to baluster (see attached.) Is there any way to create this that doesn't involve a lot of math? An array or nested families won't cut if it gets any longer than whatever the base length is designed at, and of course the column spacing (i.e. rail length) isn't consistent
ID:	38799   Click image for larger version.
    Moderator mark b's Avatar
    NSW Australia
    1,436
    09:33 PM
    4 Not allowed! Not allowed!
    You could use a combination of railing and a beam system.
    Check out this old thread
    6,389
    07:33 AM
    Interesting. I'll look into that. Thanks!
    July 7, 2017
    Hernando, MS
    614
    06:33 AM
    Baluster panel with a curved top edge, and arrayed nested pickets?
    Long Beach, CA
    208
    04:33 AM
    Quote Originally Posted by PatrickGSR94 View Post
    That was my initial thought too Patrick, using a void to cut the curve. But that solution would not allow for anything other than a curved edge along the top. Unless you have a way to control that? Mark's solution handles this elegantly.
    "OMG I killed Revit"
    dzatto's Avatar
    5,273
    06:33 AM
    What about creating a baluster panel family for all the intermediate pickets? It would infill automatically between the posts.
    Just read your comment about column spacing not being consistent, so this may not work.
    6,389
    07:33 AM
    If the spacing was consistent I could make a family, but any time the array changes it messes up the void since it doesn't cut the new instances. Going with a beam system at the moment unless they can space everything equally.
  8.    #8
    dzatto's Avatar
    5,273
    06:33 AM
    I was thinking create each picket separately at the correct height in a panel family. Don't use a void. It may stretch or truncate it a tad bit so it fits between the columns (if the spacing is off). It may get you close enough.
    Or you could create a family and just insert it between columns in the project. Don't use a railing.
  9.    #9
    3,169
    04:33 AM
    3 Not allowed! Not allowed!
    This old post of mine might be an option too.
  10.    #10
    6,389
    07:33 AM
    Well that is a neat trick! Kudos!
  1. 'Fence' with alternating pickets
    By mdsharp5 in forum Architecture and General Revit Questions
    Last Post: December 4th, 2019, 09:05 PM
  2. controlling arched top of window
    By gabrieleon in forum Architecture - Family Creation
    Last Post: January 9th, 2017, 01:26 PM
  3. Modeling arched stonework
    Last Post: September 19th, 2013, 05:09 PM
  4. Arched door on a curved wall...can we do it?
    Last Post: July 12th, 2013, 01:43 PM
  5. Round or Arched Walls
    By CADLee in forum Architecture and General Revit Questions
    Last Post: October 25th, 2012, 01:47 PM
