Results 1 to 10 of 18
Thread: Revit 2021 shadow problem
    May 5, 2020
    6
    12:53 PM
    There seems to be a problem with shadows in the 2021 version.
    In my projekt i have fasades with small recesses (3cm) in the old version you could emphazise these with the shadows. in version 2021 the shadowedges are so soft that there is no effect to be seen. Is there a way to fix this problem?
    March 5, 2011
    Southern California
    703
    05:53 AM
    Can you post 2 comparison images from 2021 and a previous version?
    Senior Member biff's Avatar
    June 13, 2011
    Australia
    903
    10:53 PM
    Perhaps you have ambient switched on ? In such a small area im thinking it could well mask hard stuff. Just thinkin'....
    May 5, 2020
    6
    12:53 PM
    Hi Scott
    shure!
    Revit 2020:
    Revit 2021:
    The settings are the same for both versions. I also cannot explain the shadows in the windows. The room behind is 6.0m deep, so here should be no frameshadows.
    May 5, 2020
    6
    12:53 PM
    Hi Biff
    ambient shadows are off :-(
    Autodesk JeffH's Avatar
    808
    08:53 AM
    Quote Originally Posted by arsherold View Post
    Shadows in a realistic view are different in 2021. Realistic views create "real time" shading and shadows, so light and shadows are being "rendered" and calculated in the view live. In 2020 and previous, the cast shadows are much more simplified.
    That said, I ran a test to see how a 3mm reveal casts shadows in 2020 and 2021. They are different, but still close to each other. Since in 2021 it is a real time render, the surrounding conditions can affect this, where in 2020 the shadows are not really rendered so they are applied universally.
ID:	38851 Click image for larger version.
    6,389
    08:53 AM
    it looks like one view is an elevation and the other is a 3D view.
    edit: unless you are using realistic mode like Jeff mentioned.
  8.    #8
    Forum Addict willsud's Avatar
    Ambleside, Lake District, UK
    1,080
    01:53 PM
    Quote Originally Posted by JeffH View Post
    Blimey Jeff, I've been waiting years for this - I'd no idea this was now possible.
    Many thanks
  9.    #9
    808
    08:53 AM
    Yes it is a 2021 enhancement. I just wrote a special Have You Tried? topic in the help about it.
    Have You Tried? - Enhanced Realistic Views
  10.    #10
    1,080
    01:53 PM
    7 Not allowed! Not allowed!
    Many thanks, this is a really useful feature. I've just switched this drawing below from Consistent Colors to Realistic Views with no other changes and you can see potential for some Views - maybe not every one as it depends on lighting but certainly a big improvement over lining up 3D Views. Interesting to see it in Sections too as it happens.
  1. Revit 2021 download issue
    Last Post: May 12th, 2020, 03:27 AM
  2. Building Coder: What's New in the Revit 2021 API
    Last Post: April 16th, 2020, 10:45 AM
  3. Revit 2015, Office 360, DB link problem, shadow data
    By Alecsx in forum Third party Add-Ins, API and R&D
    Last Post: July 31st, 2014, 11:40 AM
  4. Shadow problem
    By kroke71 in forum Architecture and General Revit Questions
    Last Post: October 12th, 2013, 07:49 PM
  5. Shadow fragmentation problem
    By jsrrd in forum Architecture and General Revit Questions
    Last Post: May 14th, 2013, 07:00 PM
