Thread: Roof terasse ''support''
    May 31, 2018
    Quebec, Canada
    136
    06:49 AM
    Hi guys,
    Is there a way on revit to establish a support plan for this type of element.
    I want to make a plan to shows all the different type of holder that we need and the quantity.
    Doing it manually takes forever, I need to cut between 2 points and do the calculation for each point on the roof. If I have 1000 holder, it is 1000 equations to do..
    Then I need to determine what type of holder to put for what height.
    Thanks for your help,
    Midaz
    December 11, 2010
    Astana
    233
    12:49 PM
    Try this way:
    1. Create a structural column-based support family.
    2. Arrange with an array without grouping.
    3. Select one support and try to Attach Top/Base to the roof with different attachment options to find suitable ones.
    4. Select all supports and attach to the roof.
  1. Roof with one plane on a different plate height **complex roof system**
    By lparnell583 in forum Architecture and General Revit Questions
    Last Post: December 7th, 2016, 09:42 PM
  2. Sloped Shed roof with Structural steel support frame.
    By billbe in forum Structure - General Questions
    Last Post: April 14th, 2015, 05:38 AM
  3. How to use downloaded roof panels family and input them on roof surface
    By kjubas in forum Architecture and General Revit Questions
    Last Post: July 1st, 2014, 11:31 PM
    Last Post: May 5th, 2014, 08:45 PM
