Results 1 to 10 of 12
Thread: CAD Link acts differently in different Revit files?
    July 7, 2017
    Hernando, MS
    609
    11:19 PM
    I have a CAD site file from our Civil engineer, which I manipulated to try to get rid of the 20-mile errors. I deleted what I don't need, turned everything on, COPYCLIP to a new file, exploded, purged, everything.
    When I link the file into my project file, I still get the 20-mile error, and it shows a bunch of spot points with elevations millions of feet away from the site.
    However if I take that exact same file and link it into a new, blank project from our template, it comes in great. No errors, nothing way out in space.
    How can that be possible for the same file to have geometry in different places when linked into different Revit files?
    December 11, 2010
    Astana
    227
    10:19 AM
    Do you use the same Link CAD layer and unit settings?
    I would change your steps "COPYCLIP to a new file, exploded, purged, everything" to "hide unnecessary objects / layers; explode; select only required objects; copy-paste to new drawing" to prevent "contamination" of the new drawing. It is better to exclude the copying (and exploding) of blocks into a new drawing, since the blocks may contain various surprises.
    3,167
    09:19 PM
    If the civil file is already linked and you are using reload or reload from I have seen the file not respond to the changes until it is removed and linked again as if new.
    I use purgeall right before using Wblock or copy/paste that way the file is cleaned of any unused block definitions that might have been revealed through an explode operation. Nested blocks are quite common and AEC elements seem to reduce with more than one explode like AEC contour > 3D polyline > Polyline > lines for example.
    Member d.stairmand's Avatar
    February 24, 2011
    Auckland
    395
    04:19 PM
    I like to use the AECTOACAD autocad Command to rip out all those nasty AEC elements
    July 7, 2017
    Hernando, MS
    609
    11:19 PM
    Thanks for the replies but none of that explains why this particular CAD file acts differently when linked into different Revit projects.
    The CAD file is a new file I just received last week. Freshly linked into the different Revit files (ongoing project file vs. new Revit file from template). CAD Link settings are the same for both, whatever is the default for our project template.
    December 11, 2010
    Astana
    227
    10:19 AM
    Another instance of the link?
    Did you run Audit?
    Wrong scale factor?
    July 7, 2017
    Hernando, MS
    609
    11:19 PM
    One instance of link per project file.
    All import link settings identical in both project files (current project file vs. new blank project file from template).
  8.    #8
    3,167
    09:19 PM
    Any other CAD files already linked into the current project?
  9.    #9
    Member HansLammerts's Avatar
    April 22, 2011
    497
    04:19 AM
    That is a wierd case. Worth examining the root cause. So what do Autodesk software engineers say about it ?? The data should be looked at. Not hunches.
  10.    #10
    December 11, 2010
    Astana
    227
    10:19 AM
    I would also try to identify the object through the Revit Query command, then delete /hide or open it in AutoCAD to fix / delete.
  1. Text acts differently
    By glkirk in forum Architecture and General Revit Questions
    Last Post: May 9th, 2018, 10:42 AM
    Last Post: November 30th, 2017, 10:15 PM
  3. Link Revit files
    Last Post: December 6th, 2012, 07:53 PM
  4. Link Multiple Revit files in one shot?
    Last Post: September 9th, 2011, 04:15 PM
  5. Point cloud files: pcg file situated differently in Revit and Autocad
    By markkus in forum Architecture and General Revit Questions
    Last Post: August 31st, 2011, 01:05 AM
