I just came across this and haven't seen it mentioned in too many places.
It seems it makes a good tip for beginners
If you select a panel in a curtain wall, and you want to avoid (tab/click selection for every panel in the same column or row of the panel you chose) then you can right click and select from the dropdown menu select panel > along vertical grid, horizontal grid, or on host
THis will select the row of panel,
the column of panels or
all the panels in the system.
Please let me know if any further clarification needed
Hope this helps!
Never knew that. Sweet.
Of course, I don't use curtain walls. But if I ever do...
